New version: RadiMation version 2016.2.10
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2016.2.8 version.
The new 2016.2.10 release of RadiMation can now be downloaded from the DARE!! web-site. Image
The following issues are fixed in this 2016.2.10 version (compared to the 2016.2.9 version):
  • #2558: Driver RadiLink as cable
  • #3534: Driver: Agilent 34980A as an oscilloscope
  • #4063: Driver Milmega AS0860-15/25 RF usb controlled
  • #4076: RadiSense III not working
  • #4213: Driver EMControl Antenna tower
  • #4259: Driver: Configurable Field Probe doesn't work with HI6005
  • #4809: Driver: Hameg HMS3010 Spectrum Analyser
  • #6142: Driver: emtest UCS500N: Telecom line surge: 2 line / 4 line
  • #6356: Driver: FCC Bulk Current Injection probes
  • #6407: Driver: IFI SMX-500 Amplifier
  • #6803: R&S ESU 40: Error -222: Data out of range FREQ:CW 4500 000 000 HZ
  • #6870: Driver HP 3458A Multimeter as AD Converter
  • #6970: Problems and overrange detected during CI Calibration
  • #7181: Driver: euro EMC RSC
  • #7244: Detect the 'Not referenced' state of the Maturo MCU controller
  • #7299: Selection of Input 2 for the TDEMI X
  • #7324: Prana MT400 Amplifier still in operate
  • #7325: Prana MT400 Amplifier not always to RF-ON
  • #7477: Driver: Bonn elektronik BLMA1060-50 Amplifier
  • #7604: Driver: BONN BLWA 0810-200/100 LAN
  • #7664: Unknown error: -1073807343
  • #7705: R&S SMT 06 Pulse modulation sometimes show a wrong pulse width setting
  • #7742: Amplifier Linearity test is not working when a variable testlevel is used during the calibration
  • #7771: R&S ESI as powermeter is measuring too fast
  • #7784: Preamplifier of Rigol DSA815 is not working in the GTEM test
  • #7814: Teseq PCJ 9201B: Unknown Device Driver
  • #7816: Driver Rohde & Schwarz BBA150 powermeter(s)
  • #7837: Driver: DARE!! Instruments BCI1004A
  • #7839: Settings to select 3 axes besides isotropic for Narda EMC 300 field probe
  • #7846: Ok button is not working caused by powermeter settings panel
  • #7850: RadiCentre 1 with RSS1006A controlled by RS232 is not working correctly
  • #7861: RadiSense is not working
  • #7862: Selecting an invalid baudrate doesn't raise a specific error message
  • #7864: Previous environmentaldata is not always remembered
  • #7865: Agilent SG 33120A is not turning on the output
  • #7871: Driver Rigol DSG830
  • #7872: Preamplifier on DSA832 cannot be activated during SB GTEM test
  • #7875: Driver CWS 500N3
  • #7891: Driver: Antenna ETS-LINDGREN GTEM 5317
  • #7895: TDEMI Device Not connected
  • #7900: Maturo MCU has slow communication
  • #7901: ControllerDelay for a GPIB controlled Maturo MCU can be 0
  • #7910: Extend PMM9010 driver to allow selection of CISPR-Average or (old-)Average as Average detector
  • #7914: Clicking on a peak in the emission frequency graph very often moves the frequency of the peak
  • #7920: Selection of DC Coupling on R&S ESW8 Input 2 is not possible
  • #7923: Driver Agilent 3499A Switch Matrix
  • #7931: Catch BONN BSA 0110-100 EXECUTION_RESULT errors
  • #7933: Optimize communication with RadiGen
  • #7938: Signal generator VI modulation frequency is incorrectly set
  • #7941: Maturo NCD controller Device Not Connected
  • #7942: How to configure R&S BBA150 amplifier communication settings
  • #7943: 1000W1000 input invalid correction file
  • #7944: Ability to set a signal generator frequency offset for AnalyzerAsPowerMeterDecorator
  • #7952: Driver: R&S FSH 8 as readout unit for field probe
  • #7960: Receiver measurement from 500 kHz - 1800 kHz on the ESI results in a timeout
  • #7968: Radimation is working in "EFT Multiband" only. The test in "EFT" is not performed
  • #7972: RGN Data out of range error during initialization
  • #7973: Control of RadiSense III raises the error: E3 Invalid Command
  • #7979: Missing test equipment in the Report Generator
  • #7982: Ability to define a power offset for the RPR RadiPower
  • #7984: RadiCentre controlled devices are not setting the RadiCentre back to local
  • #7997: R&S URV35 Level Meter as AD Converter
  • #8002: Driver: ETS-Lindgren HI-6006 Field Sensor
  • #8010: Driver DARE!! Instruments BCI1004A Coupler
  • #8012: Environmental data window unable to press OK
  • #8013: Agilent Technologies E4432B: Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
  • #8019: Compression EUT Calibration table export same for every compressionPoint
  • #8026: Driver: Hameg HMS3010 as Powermeter
  • #8062: Outside Points
  • #8153: Provide C header file for Device Driver API, to make importing in ATEasy software possible
  • #8164: Provide C header file for Device Driver API, to make importing in ETSI Power Meter 300328
  • #1391: 0% Step possible in Radiated and Conducted Immunity
  • #5347: ESPC is returning a timeout error after CAL?
  • #5907: Error detected during the start of the sweep with PMM 9010F
  • #6331: Driver: Configurable Multimeter
  • #6371: Driver: Signal Generator PMM3010
  • #6415: Driver: IFI T188-500 Amplifier
  • #6679: Driver: Tektronix TDS310 Oscilloscope
  • #6680: Driver: Tektronix TDS3052B Oscilloscope
  • #6681: Driver: Tektronix DPO3010 Oscilloscope
  • #6691: Driver: Bonn Elektronik BLWA series amplifiers
  • #6859: Driver: AR 1000W1000E
  • #7545: Driver: battery powered RadiField Polarizer RPL2010A
  • #7567: Driver: ADC NI 9215
  • #7646: Driver: Frankonia FC04
  • #7694: Pulse modulation IFR 2023B Signal generator is not turned off by sending the correct command
  • #7992: Measurement with FSV3 power meter is slow and instable
  • #7996: Raise a warning that still an outdated or old version of National Instrument GPIB software is used
  • #8018: Configurable Absorbing Clamp custom frequency range is not retained
  • #8038: Hameg HMS3010 Spectrum Analyser Error: -222, "Data out of range"
  • #8042: Hameg HMS3010 Spectrum Analyser is returning previous measured peak data
  • #8048: PMM 9010 Comport already open error when using Userport Controlled LISN and receiver simultaneously
  • #8049: Hameg HMS3010 Spectrum Analyser has restricted RBW filters for (receiver mode) QP detector
  • #8050: RadiMation crashes when using Agilent N9038A
  • #8051: ESIB 40 FFT mode cannot be active in zero span
  • #8052: Maturo MCU Turntable controller returns E-D error
  • #8055: How to perform magnetic immunity calibration?
  • #8063: Driver: Bonn BSA 1010-125 and generic series driver
  • #8073: Driver: ETS-Lindgren 3142B Antenna
  • #8074: Driver: ETS-Lindgren 11966P Antenna
  • #8076: Driver: Injection device Luthi RF current Injection clamp
  • #8078: Driver: CDN M2-M3N
  • #8080: Driver: ESD Generator
  • #8082: Driver: Bonn BLMA 1030-80 series
  • #8084: R&S FSH 8 Field probe attenuator
  • #8088: Gauss Instruments TDEMI: Specific System Error: -100,SYSTRF DEF
  • #8089: Gauss Instrument TDEMI3G: Specific System Error: -220,"Parameter Error;SYST:RF DEF"
  • #8090: RadiGen RGN start frequency can't go lower then 9 kHz
  • #8098: RGN6000B "Data out of range" error when setting carrier level above 4.0 dBm
  • #8100: Driver: TESEQ BHA 9118 Horn Antenna
  • #8102: Driver: Anapico APSIN12G Signal Generator
  • #8103: Driver: AR DC7441A Coupler
  • #8110: Ability to control the ALC mode of the Agilent N5183A
  • #8117: R&S ESPI 3 Impossible to get description string for this Error when opening ShowConfigurationDialog
  • #8119: HP3478A as Multimeter is selecting DC voltage instead of AC voltage
  • #8122: Driver: Welraton C2630-10
  • #8132: Ability to control the Pulse limiter and the Pre-selector of the PMM 9010F
  • #8135: Configurable device driver write an empty 'Get ID' query and is also trying to read a response
  • #8142: Driver: Bonn BSA series interlock
  • #8143: RadiSense V Field sensor new firmware implementation
  • #8150: Time-out and unlogic measurement values while using multiple PMM EP-601 simultaneously
  • #8161: CI calibration is not reaching the desired test level
  • #8166: LumiLoop LS Probe TCPIP controlled CI Serial Number raised an error
  • #8187: Communication problems with TDEMI 1G, selecting the input
  • #8189: Logarithmic step frequency of 0.5% is not used in a CI Calibration
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2016.2.
