This version 2024.2.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.2.6 release of RadiMation can now be downloaded from the Raditeq website.
The following issues are fixed in this 2024.2.6 version (compared to the 2024.2.5 version):
- #6508: USB controlled RadiCentre does not require National Instruments VISA anymore
- #14984: R&S ESR3 Fix an error -222 when applying the RBW after the center frequency has changed
- #15624: TDEMI unexpected differences in measurement results when the pre-selector has been activated and a reduced span is being measured
- #15708: Extended the mk motion driver to support retrieval of values from OCR
- #15746: Driver Siglent spectrum analyzer model SSA5085A
- #15761: Extended the mk motion driver to support retrieval of values from OCR
- #15848: R&S OSP switching commands are retransmitted when an error has happened before
- #15907: fixes related to double inclusion of monitorig input graph lines
- #15928: MSO 3000 series fixes related to division scaling
- #15955: Device driver to check if the serial number of the tested EUT is the same as the serial number in the EUT file
- #15963: dBm is shown along the Y-axis for a radiated emission test
- #15968: Fix AC DC coupling selection for the R&S ESCI
- #15974: R&S SMCV100B changed default port and IP adress in driver settings
- #15975: Fix setting the receiver measurement time for the R&S FPL
- #15979: Fix AC DC coupling selection for the tektronix TDS scopes
- #15980: unexpected results performing the amplifier harmonics test
- #15985: Allow lower signal generator levels in harmonics eut test
- #15986: Allow lower signal generator levels in network analyser test
- 15989: Network analyser test stimilus limit removed of -20 dBm
- #15991: Performing a final measurement with multiple detectors during a GTEM test is now working correctly
- #16000: IFI SCCX750: Fixes related to initialization behavior
- #16001: RSS2000 will not send MEASMODE with probe versions older than 2.0.6
- #16004: FSW43 Do not use AUTO sweep time while in zero span
- #16008: Improvements to rounding of floating points
- #16009: Switching relay of R&S OSP, module OSP-B136 is now supported
- #16018: EUT Serial number checker, show serial numbers in correct order when they do not match
- #16020: Make RadiSense IDN checks more strict
- #16023: Driver Keysight AP5000 series
- #16027: Teseq NSG 4070 can also be controlled using the TCP/IP connection (without an installed VISA library)
- #16040: R&S ESI Data out of range;SCAN1:BAND:RES
- #16058: Serial number checker is now able to ignore communication errors
- #16064: fixed the error message 'clsCommandSendSwitchMatrixEvent is not registered'
- #16067: use longer timeout for em test CWS500N1.3 and firmware version >= v9
- #16070: Driver: Raditeq RGN2001B
- #16075: fixed the error message 'clsCommandStopRotPositioner is not registered'
- #16080: NX7 unexpected syncronisation errors
- #16082: em test CWS500N1.3 power meter driver, use longer wait times for firmware version 9 and higher
- #16084: NX7 unexpected syncronisation errors
- #16085: Fixes related to resizing of graphs in RI multiband test
- #16086: Fix Keysight 34450A and 34405A: No measurements are performed by the device
- #16095: Fix device driver system warning ranges
- #16106: Fix label for the EFT multiband test
- #16165: The column order in correction file no longer changes when a column is removed
- #16171: Verify that the correction file check uses the start frequency of the configured band, instead of the first frequency of the frequency list.
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.2.
[/quote]
