New version: RadiMation version 2025.1.5
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.4 version.
This version 2025.1.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.5 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.5 version (compared to the 2025.1.x version):
  • #15505: Milmega: automatically detect which controller AC-001 or AC-002 is used
  • #16015: Added R&S BBA150 DDC25 couplers
  • #16066: Signal power graph is now available when a multiband closed loop field test level is used
  • #16129: Display a warning in the event log of a test if the measurement is not within the 'max difference' after the 'max measure' measurements
  • #16147: Driver: COM-POWER CLCI-400
  • #16148: Driver: COM-POWER FCLC-400
  • #16149: Driver: COM-POWER CLCE-438
  • #16150: Driver: COM-POWER FCLCE-438
  • #16151: Driver: COM-POWER AM-741R
  • #16152: Driver: COM-POWER AB-300M
  • #16153: Driver: COM-POWER ALC-100
  • #16154: Driver: Schwarzbeck FTC 101
  • #16166: Driver: Schwarzbeck 419 NJ
  • #16232: Exporting graphlines is fixed
  • #16267: Configure min/max limits for temperature, pressure, and humidity in the Netatmo environmental data provider’s advanced settings.
  • #16298: Ask the user to reattach the changed EUT attachment if its content has been modified
  • #16300: Preserve the order of the attachments when the EUT is saved
  • #16331: Change wording in RadiSense driver from "user calibration" to "user correction"
  • #16356: Driver: GW Instek GLN-5040A (LISN)
  • #16360: Driver Prana LT500DC
  • #16381: Add support for frequency translation for Signal Generators, allowing the use of frequency doublers and similar external translation devices.
  • #16395: Allow the setting of a custom negative start/end angle for the rotational positioner (within the allowed range)
  • #16409: HP34401 Sets the sample count correctly now based on available memory
  • #16422: Do not display Relay B in the advanced configuration -> "Switches" tab when only one Relay is available
  • #16425: Change wording "Software update" to "Firmware update" for all Raditeq devices
  • #16432: RPR4000 series firmware updater fix for version 4.4.1 and lower
  • #16445: Keysight U2021XA Power Meter improved IMM and FETCh commands
  • #16450: Updated several LISN drivers with correct end frequency
  • #16458: Fixes an error message for CI MB where the frequency is lower than the start frequency of the selected calibration file
  • #16459: R&S SMA100B is usable from 8 kHz
  • #16482: Prana N-DT 170/130D
  • #16494: Exporting graphlines is fixed
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
