Does the latest RadiMation contain latest device drivers?
When I update my RadiMation software to the latest version available, does this also contain the latest device drivers?
Re: Does the latest RadiMation contain latest device drivers
The development and releasing of the device driver system is normally going faster than the releases of RadiMation versions.
Therefore, it could be that when you install a new version of RadiMation, this version is not installing the latest device drivers.
So generally speaking, the latest version of the RadiMation software does NOT automatically contain the latest device drivers available.
Please update your system with the latest available device drivers from our wiki site after each update of the RadiMation software: http://data.dare.nl/wiki/index.php/Device_drivers.
If you are using multiple version of RadiMation, make sure you select the correct RadiMation version during the device driver installation progress (latest version should be selected by default).
Then you are certain that you are using the latest device driver system as well.
The answer of 'sast' indeed correct.
To say it in a different way: the latest device drivers are included with the RadiMation version at the moment that we build the RadiMation setup program. It could however be that we already make updated device drivers 1 hour later. That update is ofcourse not part of the already build and released RadiMation version.
When a customer receives the new RadiMation version after a few days, it is possible that already several device driver improvements have been implemented, and it is thus important to update the latest device drivers.
By the way: it's easy to see which version of the device drivers is installed. The installed device drivers version is shown on the about window.
