Where to define Cables for the EFT testing
Discussion and questions regarding the Pulsed immunity module (ESD/EFT/Surge) of RadiMation.
Where can I define the Cables for the EFT testing? In the manual it states “in the EUT Window”, but where in the EUT window?
Adding Cables for EFT testing None selected.png (11.11 KiB) Viewed 98432 times
Re: Where to define Cables for the EFT testing
Thank you for asking. The cables that will be shown in the drop-down menu of the EFT test window must indeed be added with the use of the EUT window.
Please go to MENU -> FILE -> NEW EUT -> and open the tab EUT Information. Now you can see ‘Cables’. With Add it is possible to add a new cable.
These cables will be available in your EFT ‘Cable under test’ drop down menu.
Adding Cable under test for PI.png (23.99 KiB) Viewed 98430 times
