New version: RadiMation version 2014.1.2
Today we released a new version of RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2013.1.26 version.
The following issues are fixed in this 2014.1.2 version (compared to the 2013.1.26 version):
  • #4449: Setup program shows a lot of Warning dialogs for the installation of uncertified windows drivers
  • #4597: Driver for amplifier Prana LT 320 DC
  • #4713: Prescan is taking to much time
  • #5069: Extend all powermeter device drivers to support the 'Reference frequency' setting
  • #5121: Cannot access the file because it is being used by another process
  • #5133: Driver R&S SMPD Signal Generator
  • #5151: Power sensor during Conducted Immunity Calibration is regulating too low
  • #5159: EMCO1050 Swap antenna polarization
  • #5164: HI-6100 fieldsensor is not set to isotropic by default
  • #5172: Turntable controller overshoot
  • #5185: Driver Prana DR220
  • #5190: Update FTDI Windows drivers for all DARE equipment
  • #5199: Extend all CTR drivers to lock and unlock the equipment
  • #5207: Peak and average is far too low after ESMI timeout for OPC
  • #5215: R&S ESU8 - EMI error Not all bytes are written to the GPIB-board within the timeout period
  • #5217: Driver PMM EP601 not recognized
  • #5221: RS ESMI Analyser timeout while waiting OPC
  • #5239: HI-6113 fiber-Optic Interface doesn't seem to function properly
  • #5244: PMM 9030 setting the input raised an error
  • #4974: Driver R&S amplifier system BBA100
  • #5174: Enable external modulation for HP 8648x Signal generator
  • #5175: HP 8116A modulation source
  • #5246: Add 'Pre Wait Time' functionality for Levelling and Monitoring measurement settings
  • #5247: Driver R&S OSP 120 switch matrix
  • #5268: Supporting modulation forms for Agilent N5181B
  • #5275: Unhandled exception object reference not set to an instance of an object
  • #1387: Auto peak sweeps
  • #5192: Increase default zoom-in factor for emission peak zoom-in
  • #5193: Continuous measure should use max-hold when turntable and antenna tower are not moving
  • #5194: Improve tracking of peaks, during a peak zoom-in
We also include several improvements and new functionalities, the most important improvements are:
  • Certified Windows Drivers are now included for the D.A.R.E!! Instruments Radi* products.
  • All powermeters can be configured to use another fixed reference frequency.
  • All powermeters are extended to have a pre-wait time. Also it is now possible to configure the powermeter measurement settings when the power is only measured (and not being levelled on).
  • Continuous measurement in a Multiband Emission test can be configured to max-hold the measurement data
  • Several improvements in the device drivers to better control the measurement equipment.
  • Zooming in on a peak with a Spectrum analyzer is now automatically adjusting the number of sweeps to correctly measure the emission.
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.1.
The new 2014.1.2 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
