New version: RadiMation version 2016.1.5
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2016.1.4 version.
The following issues are fixed in this 2016.1.5 version (compared to the 2016.1.4 version):
  • #5344: ESPI -222 Data out of range error
  • #5434: Driver: Agilent N9038A, 44 GHz option
  • #5480: Throw error or warning when 'Step Size clipped to nearest value allowed' for Agilent MXE N9038
  • #5694: Driver Amplifiers Ophir 5225E / 5264E / 5274E
  • #5786: Possibility to specify the 'auto-switch off' time of the PMM EP600-series probe
  • #5956: Units change from dBm to W in the Power Meter Module does only change unit text
  • #6273: Logarithmic step frequency for the Agilent N9038A
  • #6310: Reference level of the N9038A is not set to the specified reference level in the TSF
  • #6458: Several improvements and issues for the Agilent MXE EMI Receiver N9038A
  • #6682: Driver Schwarzbeck MDS21
  • #6683: Driver Schwarzbeck MDS22
  • #6684: Driver Schwarzbeck LISN's
  • #6685: Driver: Schwarzbeck VULB 9162
  • #6688: Driver: Bonn Elektronik amplifier BSA 0125-25
  • #6689: Driver Bonn Elektronik BSA series amplifiers
  • #6718: Numbers on Analog scale of Virtual instrument should be updated when unit is changed
  • #6792: Agilent N9038A: Non EMI average detector is change due to physcial constraints
  • #6921: Driver: Agilent N5171B-506 + UNT
  • #6940: Driver Bonn BSA 0122-20
  • #7092: Longer time till sleep mode Narda EP600/EP601
  • #7163: Errors connecting Lutron field probe
  • #7170: Actual RH values no longer visible.
  • #7173: Searching for possibility to download latest RadiMation version for driver release
  • #7175: Wrong commands for Maturo ncd for antenna and turntable
  • #7185: Unable to install the newest version, only HTTP and FTP are supported
  • #7188: Advantest TR4172 No match was found in the specified regular expression
  • #7194: Driver: Antenna Tower Inn-co GmbH MA4000
  • #7208: Checksum error with the EMTEST CWS500N1.2
  • #7217: Unexpected response from the Narda EP600 after filter setting command
  • #7220: Driver: Vectawave VBA1000-1000
  • #7238: Report generator text unexpected in bold.
  • #7241: Sending an error report takes a long time (roughly 1 minute)
  • #7246: Forward power and signal power graphs are not shown anymore in already performed tests
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2016.1.
The new 2016.1.5 release of RadiMation can be downloaded from the DARE!! web-site: Image
