The following issues are fixed in this 2016.1.11 version (compared to the 2016.1.10 version):
- #7008: Reflected power too high
- #7279: End of Surge test is not correctly detected on a Teseq NSG3040
- #7461: Unable to use formula option in AD converter
- #7485: Driver Signal Generator Keysight 33522B
- #7515: SRQ errors are generated using Tektronix TDS5034B
- #7542: Driver Amplifier IFI S41-250
- #7624: Driver Keysight Amplifier N4985A
- #7631: Agilent Technologies N9038A Scanning Receiver: Device is not aligned error
- #7638: Maximum selectable RBW for the Analyzer As Powermeter settings is 50 kHz
- #7642: Agilent N9038A set RBW raised error Data out of range; the value 0 was clipped to the minimum value of 10
- #7651: Wrong frequency range Teseq CBA 1G-1000
- #7654: Configurable Amplifier custom frequency range is not retained
- #7693: Device driver configuration of the RSS1006A (CTR1001S) field sensor
The new 2016.1.11 release of RadiMation can be downloaded from the DARE!! web-site:
