The new 2017.1.7 release of RadiMation can now be downloaded from the DARE!! web-site.
We are currently not aware of known issues in this version.
The following issues are fixed in this 2017.1.7 version (compared to the 2017.1.6 version):
- #6971: Driver: LeCroy WaveSurfer and Wave Runner oscilloscope series
- #8538: Driver: CPI Amplifier J-series
- #8541: Option to enable/disable frequency correction of PMM EP600-series
- #8553: Support Mode 4 of the RadiPower
- #8555: ErrorReport: "Collection was modified; enumeration operation may not execute. "
- #8565: Driver: Steatite atennas
- #8566: Driver: Flann Microwave antennas
- #8569: Use Internal 10 MHz out for IFR 2023 Reference clock
- #8582: Support the Preamplifier of the new TDEMI X
- #8623: line coupling is only showing 1 line coupling in VDI TSF configuration
- #8662: Object reference error while using minimum performance in a MB magnetic field closed loop method test
- #8685: AD Channel colors are the same
- #8689: Note field cannot be larger then 1000 characters.
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2017.1.
