This version 2018.1.4 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2018.1.4 release of RadiMation can now be downloaded from the DARE!! web-site.
The following issues are fixed in this 2018.1.4 version (compared to the 2018.1.3 version):
- #5261: Frequency plot can't be printed
- #5636: R&S ESPI 3 error Data out of range SCAN1:BAND:RES
- #5783: R&S ESU 26: Error -222: Data out of range. Depending on the preamplifier that is used
- #6373: R&S ESU 40: Error -222: Data out of range SCAN1:BAND:RES 1 KHZ
- #6811: Add new RadiMation startup Reseller logo
- #7329: Using multiple bands that switch preamplifier on and off gives error: R&S Receiver ESU 8
- #7482: RBW and SpanCentreFrequency order. Unable to set frequency multiband
- #7728: Unicode: clsFile EUT information is saved as ascii. Unicode characters are saved and read as '???'
- #8600: Spectrum Analyser frequency out of range with PreAmplifier MB
- #8691: Frequency out of range at second measurement.
- #8730: Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
- #9129: RadiMation crash when GPIB-Board is not installed or not configured correctly (GPIB-EDVR)
- #9177: Unable to open measurement files (_Object reference not set to an instance of an object..)
- #9188: Corrupt testfile, no data is visible in the graph
- #9221: Receiver (ID1691) Input 2: Specific System Error: -222,"Data out of range; SCAN1:BAND:RES 1 KHZ"
- #9247: Wrong output for Keyword ||DESCRIPTION||
- #9274: Driver: Field probe Narda EMC-30 RS232
- #9275: Driver: Passive drivers Philips Saeco S.p.A.
- #9277: Driver: Passive drivers CDVI Wireless S.p.A.
- #9278: MB test with Carad as eut controller gives an error
- #9287: Test data disappeared
- #9293: Radimation restarts during emission measurements (read/write outside the bounds of array)
- #9310: Testdata again not visible
- #9311: Test data lost / not visible
- #9335: VI Window crash at closing
- #9338: Driver: Shaffner Broadband Horn Antenna 1-18 GHZ
- #9339: Driver: Stanford Research Systems - Model DS335
- #9341: Driver: Agilent N1913A
- #9345: De index ligt buiten de matrixgrenzen - Index out of range
- #9363: Driver: CDN LAPLACE S46 ST8
- #9364: Driver: LISN LAPLACE (Cranage) LISN16A1P
- #9365: Driver: Antenna Laplace SA1020/RF200 No remote control
- #9366: Driver: Injection device Teseq KEMZ 801
- #9367: Driver: Calibration JIG Teseq KEMZ 801
- #9368: Driver: CDN MEB M3, M2, AF3-1 and AF2-1
- #9369: Driver: Antenna ARA LPB-2513
- #9382: Unable to ReportGenerate Emission and Peak Table
- #9398: Driver: Bonn BLMA 2060-30
- #9409: R&S ESI does not show graph of logarithmic stepped sweep
- #9426: Subject of ErrorReport should contain the description of the error
- #9428: Transmitting an ErrorReport is not working, complains that it is not possible to send ErrorReport
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2018.1 .
