New version: RadiMation version 2019.1.9
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2019.1.8 version.
This version 2019.1.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2019.1.9 release of RadiMation can now be downloaded from the DARE!! web-site. Image
We also include several improvements and new functionalities in version 2019.1.9, the most important improvements are:
  • General code improvements
  • 24 improvements or fixes
Noteworthy new device drivers that have been added:
  • Teseq RFB 6000
  • Keysight 34465A AD-Convertor
The following issues are fixed in this 2019.1.9 version (compared to the 2019.1.8 version):
  • #8314: Communication is getting out of sync using a Configurable Antenna Tower driver
  • #9847: RBW changed, radimation halted.
  • #9935: Interlock errors are raised by an AR 5000A250A
  • #10113: Mini-Circuits PWR-SEN-6LRMS-RC
  • #10171: Polariser & antenna tower driver RAT1001B for use with RadiPol RPL2010A
  • #10172: EMCO2090: Turntable - No notification when using a turntable position higher when the limit for he EMCO2090 is set at 180 degrees.
  • #10242: Driver: TESEQ RF Switch RFB 6000.
  • #10257: Object reference not set to an instance of an object.
  • #10275: Error with FM modulation.
  • #10334: Hewlett Packard 34401A (Multiple)- Device Not Connected.
  • #10344: When I zoom in the limit line is moving.
  • #10349: How to frequency range PMM 6630?
  • #10358: Keysight Technologies N9322C: Specific System Error: -222,"Data out of range;BAND:TYPE CSP2
  • #10362: When we want to print Start-Stop frequency we only get the result from the last band.
  • #10375: Radimation crashes when checking the driver for R&S NRX.
  • #10384: Add the Tracking generator option to ESR 7 & ESR 3.
  • #10392: Driver: Keysight 34465A AD-Convertor.
  • #10402: Spectrum Analyser 8563A - ERR 112 ???CMD??? Unrecognized Command.
  • #10459: Der_Objektverweis_wurde_nicht_auf_eine_Objektinstance_festgelegt
  • #10464: Error connecting FCU: Not able to connect over IP.
  • #10500: DARE!! Instruments RGN6000B HF (USB): Setting the output raised an error.
  • #10511: RadiSense 10 Upload User Calibration table
  • #10513: Extend maturo fcu clamp mover driver with speed configuration.
  • #10521: Checking the driver for R&S NRX indicates that the device is not connected
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2019.1 .
