New Version: RadiMation version 2021.1.7
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2020.2.10 version.
This version 2021.1.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.1.7 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following features are added to RadiMation 2021.1
  • EUT Monitoring during EFT and Surge testing.
  • Radar Pulse gating modulation.
  • Power measurements of modulated signals.
  • Show values in graphs below -100 dB.
  • Pasting table data into EUT General Information.
  • Pasting table data into Cables.
  • Calibration of field harmonics using an antenna and an analyser.
The following issues are fixed in this 2021.1.7 version (compared to the 2020.2.10 version):
  • #11714: Out of memory during printing
  • #11716: Driver: Frankonia EFS-Laser
  • #11753: Cable table column chooser is overwritten with the copy context menu
  • #11664: Driver: R&S RTO2024 as a dual input powermeter/analyzer.
  • #11673: Multiband immunity modulation configuration dialog is shown too small by default
  • #11674: Warning regarding pulse time is still shown when PM is disabled
  • #11675: Multiple messages in notification area of modulation configuration is are not readable.
  • #11676: Up and down of the pulse gating repetition time are now working
  • #11677: Modulation configuration error links to an unknown knowledgebase page
  • #11706: ErrorReport: "Object name is shown instead of limit line value when trying to configure a limit line
  • #11711: Index out of array
  • #11713: Changed EUT details not stored when closing EUT file.
  • #11684: Cannot enable modulation
  • #11651: EUT Monitoring graphs are not shown in the frequency graph, but are available in the time graph
  • #11617: No measurement results when using a frequency list.
  • #11593: Out of memory exception raised while using CLI.
  • #11598: Harmonics calibration based on field measurement is not able to use spectrum analyzer
  • #42: Add EUT Monitoring Input support for the EFT, ESD and Surge tests
  • #4161: Multiband power measurement seems to limit at -100 dBm
  • #4525: Support the gated pulse modulation.
  • #5807: The minimum value of the dBuV/m should be around -67 dBuV/m
  • #5836: Lower the minimum values for magnetic fields to far below -100dBuA
  • #10454: When reading out the data of the powermeter with a switch matrix it seems that it is uncorrected
  • #10457: Importing EUT Data
  • #11093: Average trace is not visible when below -100
  • #11165: Project: Simplify copying of customer provided data into an EUT file.
  • #11189: Send corrected forward power value to switch matrix
  • #11214: min/max values and division marks are not shown during display of graphs
  • #11340: Could not find default endpoint element that references contract 'RadiLogService.IRadiLogService' in the ServiceModel client configuration section.
  • #11343: Unclear message: 'Please connect the powermeter to the power reference.' during amplifier compression system calibration test
  • #11433: Item #154 -Loading the device driver list (amplifiers) is taking longer than expected
  • #11435: Amplifier control window position is not remembered on restart
  • #11436: Amplifier control window issues
  • #11464: RadiMation installer must not install the example directory in the program files(86x) folder
  • #11465: Changing the installation directory of RadiMation does not work.
  • #11493: When using a R&S NRVD the frequency correction is not set to ON.
  • #11528: Status of actual status of a multiband immunity test is not clear in the skinned version
  • #11568: No graph for low frequent magnetic field emission measurement
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.1 .
