This version 2021.3.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.5 release of RadiMation can now be downloaded from the Raditeq web-site.
The following features are added to RadiMation 2021.3
- The number of vertical divisions of a graph can be configured
- Disabling continuous measure is not confusing anymore
- Expected *IDN? of the majority of device drivers can be modified
The following issues are fixed in this 2021.3.5 version (compared to the 2021.3.3 version):
- #12120: ErrorReport: "Peak detection and selection can be on a higher emission"
- #12188: Not always the highest peak is selected
- #12297: Frankonia FC06-1 Antenna mast communication problem
- #12300: Test initialization error.
- #12312: Frankonia FC 06.1 Controller Antenna mast error
- #12313: Frankonia FC06.1 Turn table controller error
- #12316: The antenna height increment of the Frankonia FC06.1 not work
- #12317: Driver: Vectawave VBA230-80
- #12318: Driver: Rigol DSG 815
- #12335: Error during radiated emission.
- #12310: Antenna distance is very often reset to 1 cm in version 2021.3.1
- #12339: Allow RI Magnetic field tests based on forward power
- #12360: MB fixed forward power does not regulate to test level
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
