New version: RadiMation Version 2021.3.10
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.3.8 version.
This version 2021.3.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.10 release of RadiMation can now be downloaded from the Raditeq website. Image
The following features/drivers are added to RadiMation 2021.3
  • #12876: Device driver: Bonn amplifer - bonn 0830-250/100/60D - 3 bands
  • #12742: Driver: Teseq NSG 3040A
The following issues are fixed in this 2021.3.10 version (compared to the 2021.3.9 version):
  • #11926: Device driver LISN EMTEST DCD-sr <surge coupling network>
  • #11927: Device driver LISN EMTEST DCD-st <surge coupling network>
  • #11932: RE SB graph is not entirely visible on screen
  • #12222: Issues when using the surge advanced config of the EM-Test NX5
  • #12653: Proximity Magnetic Field Test (RS101 like) | Rigol DSA815 failed.
  • #12655: Hameg HMS3010: Device Driver Function Not Implemented
  • #12731: About quasi peak
  • #12741: RTE1024 driver error -200 Execution error
  • #12745: Device driver for EM-Test NX series with DCD(5-A b-8-4) <surge coupling network>
  • #12752: The graph for a emissions sweep is not entirely visible on screen
  • #12761: Radipower async communication after setting the active measurement frequency
  • #12763: Should it be possible to add multiple subsitution testlevels within the same band configuration
  • #12794: Can not connect to the antenna tower RFS2006B
  • #12814: Rohde & Schwarz NRP6AN (Power sensor) Conducted Immunity Test - Can't connect device
  • #12815: Driver: RadiSense 10 Essential
  • #12819: Rohde & Schwarz FSP 30: Specific System Error: -222,"Data out of range;SWE:TIME 17 MS"
  • #12820: Attenuation precision is not copied over to new test/ calibration files
  • #12830: VI instruments DeviceSpecificInputs are updated while the device is not auto triggered
  • #12831: Reconnecting to a VI Instrument will reset the trigger settings.
  • #12383: Copying devices and device settings.
  • #12844: PMM 3010 SG Error when activating Square modulation.
  • #12862: Questions regarding the CLI report generator
  • #12866: Add R&S RT-ZC20 current sensor driver
  • #12876: RTO/RTE the power meter (Span x RBW) settings are not set as expected
  • #12872: RTE1024 Sytem Error -400
  • #12874: NSG3040A cannot connect during second IDN during Init() while CheckDevice() is succesfull
  • #12875: Device driver for R&S FPC1000 error during 61000-4-39 calibration.
  • #12914: Configuration dialog of Inn-co CO 3000 (Unit 1) positioner cannot be shown
  • #12922: Clamp moving wrong positions.
  • #12925: Rohde & Schwarz RTO2034 oscilloscope driver is an unknown device driver
  • #12931: Surge Multiband EXT
  • #12940: RS issue
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
