New version: RadiMation Version 2022.2.3
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2022.2.2 version.
This version 2022.2.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.2.3 release of RadiMation can now be downloaded from the Raditeq website. Image
The following features/drivers are added to RadiMation 2022.2
  • #13011: Driver: COM-POWER ARI-6000-100
  • #13012: Driver: COM-POWER ARI-1000-200
  • #13013: Driver: COM-POWER ACS-250-100W
  • #13014: Driver: SIGLENT SSG3021X
  • #13015: Driver: Anritsu 68369A
  • #13016: Driver: COM-POWER LI-3P-232
  • #13017: Driver: COM-POWER AC-220
  • #13018: Driver: COM-POWER AB-900A
  • #13019: Driver: COM-POWER AL-100A
  • #13020: Driver: COM-POWER CLA-150A
  • #13021: Driver: COM-POWER PAM-103
  • #13022: Driver: COM-POWER PAM-103
The following issues are fixed in this 2022.2.3 version (compared to the 2022.2.2 version):
  • #12600: Frankonia FC06.1 Antenna mast 1 polarization change still has problem in changing polarization
  • #12928: Test equipment Monitoring tab Add/Edit/Delete buttons are not correctly placed
  • #12933: Pressing cancel on the advanced option password prompt results in an invalid password error
  • #13004: Check version number of LAN controlled RadiCentre
  • #13035: Resolve compile errors of device drivers when using C++17 compiler settings
  • #13036: VisaBase::GetUsedVISACommunication returns another response than expected when VXI-11 is used
  • #13059: The control of the Frankonia FC06.1 controller is not working
  • #13085: Configuration dialog of R&S NRT powermeter driver raises a wxWidgets Debug Alert
  • #13107: Controlling the Schwarzbeck TK9420 LISN raises an 'Unknown SetValueID'
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.2 .
