New version: RadiMation version 2023.1.8
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.1.7 version.
This version 2023.1.8 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.1.8 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.1.8 version (compared to the 2023.1.7 version):
  • #13843: AD-Converter Keithley (Scanner) shows error -133 undefined header on the display.
  • #13847: Timeout error when using filter 12
  • #13853: Events are not shown in the events tab of a multiband radiated immunity test
  • #13864: RE MB test window - peaks tab is broken
  • #13869: Conducted Emission MB test is raising a object reference error
  • #13863: Driver: Amplifier Research FL8018 + FI8000
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.1 .
