New version: RadiMation version 2023.2.4
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.2.3 version.
This version 2023.2.4 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.2.4 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.2.4 version (compared to the 2023.2.3 version):
  • #5383: Implement 'Ignore height change' settings for the NCD AT
  • #6879: Maturo MCU cannot ignore height change
  • #9153: Average too high in Final Measurement sweep
  • #9332: Final Measurement - average
  • #12150: AD-Convertor device driver as a Decorator around a spectrum analyser driver to measure AM/FM/Pulse-modulation
  • #12236: Driver: Rigol RSA5065 to use multiple traces in EMI mode
  • #12482: Support tracking generator on Rigol RSA5065
  • #12797: Driver: Rigol RSA5065 EMI-Mode
  • #12799: Rigol RSA5065 Tracking generator
  • #13049: Driver: Siglent SVA1032X
  • #13402: Measurement using Cispr AVG detector in the EMI-Mode of the Rigol RSA5065N
  • #13602: I/O Error with Rigol RSA5065
  • #13857: Qpeak not visible in peak table after making adjustments to the peak table.
  • #13987: Re-implement MCU antenna tower limits as pure software limits,
  • #13924: The name or number of the point in the UFA calculation cannot be modified
  • #13939: Include more logging during start of RadiMation to identify what causes startup time
  • #13956: The last used graph exporter type should be remembered
  • #13983: Environmental information is inserted as boolean value in RI printout reports
  • #14000: Rigol RSA5065 Communication Error
  • #14031: RadiSense has invalid user calibration table.
  • #14038: Implemented a change to not reduced the sweep time when the average or rms detector is activated for r&s esu based drivers like the esw
  • #14041: It is not possible anymore to use a key on the keyboard to select an entry from a dropdown list
  • #14053: RSA5065(EMI mode): RBW cannot be set to 9 kHz, changes back to 1 MHz
  • #14054: AR FM5004 Driver issue with channel selection
  • #14055: conducted emission in RSA5065 EMI mode
  • #14063: FA 7006 Issue with termination characters on legacy commands
  • #14076: Hide the "Move antenna height" and Move distance" setting from the change order
  • #14080: Driver: Siglent SSG5060X
  • #14081: Radiated Immunity MB test is corrupt in 2023.2.3
  • #14085: Add Advanced option:"Emission.Multiband.Sequence.AllowPeakReview"
  • #14086: Driver PMM 6630 does not handle *** correctly
  • #14092: Improvement Amplifier linearity, remove 10dB Limit?
  • #14095: Driver: ETS-Lingren 3166 & 3167 TEM Horn antennas
  • #14097: Multiband GTEM not possible to configure the antenna distance
  • #14099: Emission test using Rigol RSA5065 - Analyzer Reference Level not as defined
  • #14100: RadiCentre returns VI_INP_PROT error when the expected response size is less than the actual response size
  • #14113: ESD Keywords are not working
  • #14114: Repetition rate has no unit in report in EFT Report.
  • #14116: More antenna steps in MB GTEM test results in unexpected results
  • #14119: Turn table min/max positions are incorrect
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.2 .
