New version: RadiMation version 2024.2.3
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.2.3 version.
This version 2024.2.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.2.3 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2024.2.3 version (compared to the 2024.1.x version):
  • #3410: Multiple TSF files can be selected at once to be added to a sequence
  • #4637: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #5552: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #8304: Multiple TSF files can be selected at once to be added to a sequence
  • #9475: Multiple TSF files can be selected at once to be added to a sequence
  • #10948: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #12806: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #13366: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #14078: Graphlines are shown for a band, also if the actual tested frequencies are not matching with the band start-stop frequency range
  • #14285: Graphlines are shown for a band, also if the actual tested frequencies are not matching with the band start-stop frequency range
  • #14327: DevExpress color selection tool is used where colors can be configured in RadiMation
  • #14428: ESR7 Changes RBW from 9 to 10 kHz when measuring PK+AVG or AVG
  • #14441: Last selected TSF directory is remembered when 'adding' a test to a sequence
  • #14454: Multiple TSF files can be selected at once to be added to a sequence
  • #14490: A device driver can be duplicated using the 'Duplicate' button on the device driver configuration window
  • #14640: Multiply value in EUT monitoring input can be set more accurate than 0.001
  • #14745: Upgrade dotnet framework dependency to 4.8
  • #14780: Invalid characters are not used anymore in RadiWiki page names
  • #14791: Support for transparent colours
  • #14798: Drop down button is shown for the selection of the line style in the graph customization
  • #15109: Restart RadiMation after updating the driver using the update checker
  • #15209: Allowed deviation for reverberation chamber according IEC 61000-4-21:2011 is provided
  • #15272: Add macro to skip all unfound keyword in report generator
  • #15358: Raditeq RPR4006R powermeter can also be used in combination with RadiBCI card
  • #15422: Driver: Teseq CBA 6G-100D
  • #15485: Customized printout template with extension other than word documents are working again
  • #15503: Multiple report generator codes with digit only content are not converted into a single numeric value in Microsoft Excel anymore
  • #15531: If skip unknown mainkeywords is activated, a known and available test is not detected as unknown anymore
  • #15569: Serial number of RadiSense probe can be retrieved using the general test information retriever
  • #14602: Driver: Netatmo module, to retrieve temperature, humidity and pressure from Netatmo devices
  • #15286: Fixed an issue where opening test results could hang due to a deadlock
  • #15500: Pevent that MatchesString causes a crash in Microsoft - STL - xmemory
  • #15502: Improved stability when multiple RadiSense devices are controlled in parallel
  • #15528: Cryptographic library updated to latest version
  • #15564: Improved automatic refreshing of Netatmo access token
  • #15566: 'General test information retriever' settings are stored in the correct section
  • #15571: Connecting to RadiPower RPR2006P does not take 60 seconds anymore
  • #15597: Stopping of the test results in power output before stopping
  • #15619: Detected USB device stream identifier number is updated in the identifier textbox
  • #15628: Updated to the latest Microsoft C++ compiler
  • * 15629: Updated to the Microsoft C++ 14.42.34433 runtime
  • #15631: Update InnoSetup to 6.4.1
  • #15636: Build wxWidgets using the C++ 20 compiler
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.2.
