This version 2024.1.10 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.1.10 release of RadiMation can now be downloaded from the Raditeq website.
The following issues are fixed in this 2024.1.10 version (compared to the 2024.1.x version):
- #13537: When saving files fewer intermediate temporary files are created and then deleted again.
- #14555: Improved R&S NRT configuration screen and added option checking
- #15491: Fix rotate maturo turntable from 0 to 360 degrees
- #15665: The 'Save as' menu for a new TSF file now loads much faster when there are many directories and files.
- #15690: Configurable EUT controller now replaces the correct __polarisation__ value
- #15717: R&S NRT Calibration table selection added
- #15739: Fix Maturo does not start movement
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.1.
