Automatic setup of AD Converter Min & Max
New ideas and suggestions for additional functionality in RadiMation can be added to this forum
alag
Post by alag »
Hey
When using RadiMation with Conducted Immunity, it is a little annoying having to set up the "Min" and "Max" range for the AD Converter manually, after first calculaing the values, based on a ideal value, measured without interference on the EUT.
Instead of this, it would be awesome if the program could just take a measurement with the AD Converter as the first thing when starting a new test, and create Lines in the graph, based on a tolerance specified in the EUT file by the user.
For example:
if you are measuring an analog output, the program would start with taking a measurement, that shows, that unaffected, its 12,045mA. the user would then have specified a tolerance of e.g 0,1%, and the program would automaticly set a Min range of 12,032955mA and a Max range of 12,057045mA
I hope this is something we will see in the next version of RadiMation, since it would be a much better user experience
Otherwise great program!
Re: Automatic setup of AD Converter Min & Max
Thank you for your suggestion. We agree that this would be a nice improvement for our software.
We created a new item for this wish, referring to #79630: Automatic setup of AD Converter Min and Max settings.
In the future we will going to implement this functionality.
