Pulsed Immunity Test optimization
New ideas and suggestions for additional functionality in RadiMation can be added to this forum
tha-paul
Post by tha-paul »
Dear all,
I have some ideas/suggestions regarding the EFT and Surge Multiband test.
1. In the EFT Multiband test, i have several sequences for e.g.:
- 1kV positive with coupling on L
- 1kV negative with coupling on N
Idea/Suggestion: It would be very helpful, if there would be a short break between the sequences, to note the test status (passed or failed)
2. When the EFT/Surge Multiband test is running, it would be helpful if Radimation would show the current running test. For e.g. in the Surge Multiband test I have a sequence like:
- 1kV; +/-; 0° 90° 180° 270°, L to N
When this sequence is running, I have no overview about which angle or polarity is currently running.
Idea/Suggestion: A small new window or a indicator which setting is currently running.
It would be very helpful if those suggestions could be implemented in the future :)
tha-paul
Re: Pulsed Immunity Test optimization
Post by tha-paul »
any comments here?
Possible to implement this ideas?
Hello tha-paul,
Regarding topic 1:
I have created a new wish for the requested functionality to be able to pause a EFT/Surge test after a sequence is completed so that the test engineer can update any relevant information such as the pass/fail state of the sequence.
Regarding topic 2:
When a single sequence entry is configured to test for example on multiple phase angles, the actual active phase is indeed not shown to the test engineer. As a work around you could define one sequence per each state that is tested so that the highlighted sequence in the status overview is only applicable to a single test case.
For now i will also create a ticket regarding this request to see if the current functionality can be improved regarding more clear indication of the active test parameters.
I hope to have informed you for now,
With kind regards,
tha-paul
Post by tha-paul »
any news regarding the topics here?
