Guide to manually remote control a turntable
Posted: 17 Jun 2013, 12:35
Open the 'Device drivers' window by clicking in the menu -> 'Configuration' -> 'Configuration' (figure 1.1) and then on the correct tab or open it directly by the menu -> 'Devices' ->
'Configure...' (figure 1.2).
1.1 menu - configuration - configuration.png (21.65 KiB) Viewed 25411 times
1.2 menu - devices - configure.png (29.37 KiB) Viewed 25411 times
Then click on the dropdown menu and select 'Turntables' (figure 2).
2. devicedrivers_turntables.png (32.99 KiB) Viewed 25411 times
Click on the 'New' button to create a new turntable device (figure 3.1) and the device driver database will be searched when you start typing (figure 3.2).
3.1 devicedrivers_turntables - new.png (28.49 KiB) Viewed 25411 times
3.2 devicedrivers_turntables - search.png (24.68 KiB) Viewed 25411 times
When the corresponding device is found, select this device driver from the list and click 'New' (figure 3.3).
3.3 devicedrivers_turntables - select and create new.png (17.55 KiB) Viewed 25411 times
A new window will be showed where you can change the description (figure 3.4).
3.4 devicedrivers_turntables - description - ok.png (11.66 KiB) Viewed 25411 times
Click 'Ok'. Your device driver is now added to RadiMation.
To configure the new device, open the advance configuration by double clicking it from the device driver list (figure 4) or by selecting your device and then click on the 'Edit' button.
4 devicedrivers_turntables - open device advanced configuration.png (25.82 KiB) Viewed 25411 times
Now the device driver configuration window (figure 5.1) is opened.
5.1 devicedrivers_turntables - advanced configuration.png (31.52 KiB) Viewed 25411 times
Click the 'Advanced' button and from the newly opened screen (figure 5.2) the 'GPIB' button.
5.2 devicedrivers_turntables - advanced configuration open GPIB.png (13.46 KiB) Viewed 25411 times
Configure your GBIB address in this window (figure 5.3). Confirm and close all underlying screen by clicking on the 'Ok' buttons.
5.3 devicedrivers_turntables - advanced configuration GPIB configuration.png
5.3 devicedrivers_turntables - advanced configuration GPIB configuration.png (17.99 KiB) Viewed 25411 times
After this configuration it is recommended to perform a quick 'Check' (use the button from figure 5.1) to see if these communication settings are correct and the device is recognized (figure 5.5).
5.5 devicedrivers_ settings check passed.png (13.61 KiB) Viewed 25406 times
Repeat this process and add for the 'Antennas' device driver type a new 'Virtual Antenna' and for the 'Receivers/Spectrum analysers' type a new 'Virtual Spectrum Analyser'.
Now with these devices (Turntable, antenna and spectrum analyser) we have to create a new test site/test equipment, before we can control the turntable.
Click in the menu -> 'Test-Sites' -> 'Configure...' (figure 6) and click the small 'Add' button in the new window to create a new Test Equipment (figure 7.1).
6 menu - test-sites- configure.png (30.56 KiB) Viewed 25411 times
7.1 test equipment - add new test equipment.png (33.41 KiB) Viewed 25411 times
Give a new name to your Test Equipment e.g. 'Virtual + Inn-Co CO 3000'. Click on the 'Ok' button to confirm (figure 7.2).
7.2 test equipment - name of new test equipment.png (10.08 KiB) Viewed 25411 times
Start adding devices to this Test Equipment by clicking on the large 'Add' Button and selecting the correct device driver type and name (figure 7.3).
7.3 test equipment - add devices to test equipment.png (52.2 KiB) Viewed 25411 times
Repeat this process for all other devices which are necessary to add. The devices are categorized into several tabs. So for instance if you want to add a Spectrum analysers, first open the 'Standard 2' tab (figure 7.4).
7.4 test equipment - add devices (tab2) to test equipment.png (31.97 KiB) Viewed 25411 times
We have succesfully added our needed devices and create a Test-site/Test Equipment which are making use of these devices.
Now we are able to start a new test. To perform any test it is needed to have an EUT file opened. So we are going to create one.
Create a new EUT file by the menu -> 'New' -> 'EUT' (figura 8.1) or simple by the shortkey 'CTRL + E'.
8.1 menu - New - EUT.png (22.21 KiB) Viewed 25411 times
Enter a file name e.g. 'Testing Inn-Co CO 3000' and click 'Save' (figure 8.2).
8.2 menu - New - EUT save as.png (67.64 KiB) Viewed 25411 times
Leave this (newly opened) EUT screen open to be able to perform any test. Select from the menu -> 'Tests' -> 'Radiated Emission' -> 'Manual Mode' (figure 8.3).
8.3 menu - Tests - RE - Manual Mode.png (34.31 KiB) Viewed 25411 times
Select the Test Engineer you want to use for this test and confirm with 'Start Test' (figure 8.4): the test window will be opened.
8.4 Tests - RE - Manual Mode - select Test Engineer.png (8.92 KiB) Viewed 25411 times
Finally it is yet needed to select a Test Equipment, use the 'Select' button (figure 8.5).
8.5 Tests - RE - Manual Mode - select Test Equipment.png (165.34 KiB) Viewed 25411 times
Now, in this manual test it is possible to remote control your turntable (figure 8.6).
8.6 Tests - RE - Manual Mode - Turn Table settings.png (4.52 KiB) Viewed 25411 times
