Guide to make a new configurable device driver
Posted: 25 Sep 2012, 13:45
Despite the wide variety of supported device drivers you may still find that your device is not (yet) available in the device drivers list. In some cases it is possible to make a new configurable device driver untill RadiMation has added your device. This can be achieved by the following steps:
Click in the menu Configuration --> Configuration. Then open the tab Device Drivers and select your device type. In this particular example select 'Antennas' from the pull down menu. Now click the 'New' button and search for 'configurable antenna', as shown in the figure 1 below.
1new antennas search for.PNG (56.2 KiB) Viewed 7510 times
1 Device Drivers
Select the 'Configurable Antenna' and hit the 'New' button. Now you can enter the description (type) of your device driver (figure 2) and click 'Ok'.
2 Description
The configurable device driver is now added. Select it and click 'Edit' to configure the settings (figure 3).
3 Settings
Here you may enter the 'Brand' name if you like. On the right click the 'Advanced' button. It's important to enter the correct Start and Stop frequency and then click 'Ok' (figure 4).
4 Start and Stop Frequency
Now you are ready!
