How can I add drivers of uncontrolled hardware like LISN's?
This forum contains all kind of frequently asked questions.
Re: How can I add drivers of uncontrolled hardware like LISN
RadiMation® uses drivers for all devices used during an EMC measurement, even passive components. With passive components this may seem an overkill, as nothing is being changed/controlled with the device. Frequency limitation is the main reason, if RadiMation® does not know the frequency range, it can not warn you that you are making possible mistake. To add a passive component yourself, you go to the device group in the configuration window.
For example, a LISN.
1.Select "Configurable LISN" and press the New button.
2.Name device correctly, and press Ok.
3.Select the device in the configuration window, and press Edit.
4.In the device configuration window press the Advanced button.
5.Change the frequency settings to match the specification of the device, and press Ok.
For all other passive devices there are configurable devices available.
