Creating a pause in a multi-band test
Is it possible to create a pause in a multi-band test ?
Re: Creating a pause in a multi-band test
There is no real pause inside multi band, but in general the only time you need a pause is when changing the test set up. For this you can use the before and after action in the test set up.
Is it also possible to use the 'Cancel' button while performing a multiband test, when actually a pause is desired?
