How can I turn off the login window?
Re: How can I turn off the login window?
To turn off the log in window of RadiMation, select an engineer that has no password selected.
Log in as Administrator:
1.Go to Configuration --> Engineer
2.Select Administrator
3.press Edit, a new window will appear.
4.Press Change Password.
5.Fill in the old password (default: Radimation)
6.Do not fill in password and retype password.
7.Close all windows with Ok.
8.Select File --> Change Engineer
9.Select Administrator
10.Check automatically login with this engineer.
11.Press Ok.
12.restart RadiMation®
Log in as other user:
The same sequence as the Administrator applies to the engineer. Make sure when you create a new engineer that the permissions are set correctly.
11.Press Ok.
