New version: RadiMation version 2018.1.7
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2018.1.5 version.
This version 2018.1.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2018.1.7 release of RadiMation can now be downloaded from the DARE!! web-site. Image
The following issues are fixed in this 2018.1.7 version (compared to the 2018.1.5 version):
  • #5636: R&S ESPI 3 error Data out of range SCAN1:BAND:RES
  • #6351: How to configure the Monitoring input channel setup for the used AD Converter device driver
  • #6377: How to enable or customize the borders of the grid of the exported table information of the ||EQUIPMENT TABLE|| keyword
  • #6380: Would it be better to do fewer sweeps with a long sweep time or many sweeps with short sweep time?
  • #6392: How is the Monitoring input channel formula option used?
  • #8434: Dongle Failure ZF Friedrichshafen AG
  • #8495: Not checked before Power delivery check if the RadiField amplifier is still in operate
  • #8547: Some report generator codes no longer work
  • #8751: Renaming a test-level input in a multiband immunity test, removes the second, if they both have the same name.
  • #8760: The CheckDevice check for Amplifier Research amplifiers using the P0/P1 command set is always succesful
  • #8795: Driver: switch matrix: MCC USB-ERB24
  • #8797: Driver: Antenna tower controller HD GmbH IEEE488-16REL GPIB
  • #9055: Remote operation of the RadiLink is not always indicating error situations
  • #9142: Driver: Mini-Circuits PWR-6GHS
  • #9203: RadiSense probe returns unknown ERROR 101
  • #9331: Radiated immunity RF on but not scanning
  • #9547: Schloeder CWG500 is waiting forever on a discharge trigger
  • #9551: Problem with ECU-6 Communication
  • #9559: RF Amplifier (ID1344): Prana returned a warning state.
  • #9575: Problems controlling the Keysight Technologies CXA (N9000B)
  • #9590: Index was outside the bounds of the array. clsDataIdentifiers.Add
  • #9591: Object reference not set to an instance of an object: ctlControlStop.CancelCommands(
  • #9604: Report Error does not handle polish characters
  • #9610: Driver: Amplifier VBA250-80
  • #9611: Driver: Clamp Schwarzbeck CVP 9222B
  • #9612: Driver: CDN FCC-801-M2-16
  • #9613: Driver: LISN - Rohde & Schwarz: ENY 41
  • #9614: Driver: Pulse Limiter - Rohde & Schwarz ESH3-Z2
  • #9615: Driver: LISN - Schwarzbeck CAT3 8158
  • #9617: Driver: Calibration Adapter FCC-801-150-50
  • #9632: Spectrum Analyser (ID1691) Input 2: Specific System Error: -420,"Query UNTERMINATED; FREQ:STOP?
  • #9644: Antenna and turntable do not return to zero
  • #9645: R&S ESCI 7 - RBW switches to auto 3 MHz
  • #9647: Closing a device window crashes radimation - Exception has been thrown by the target of an invocation
  • #9673: Collection was modified; enumeration operation may not execute.
  • #9685: Attachments of the EUT File are corrupted
  • #9701: Driver: Keysight Technologies MXA N9020B + CXA N9000B
  • #9709: Driver: Schaffner SCR 3501
  • #9713: Communication time out RPR2006C
  • #9754: test interrupted with "Cancel" and resumed with "Automatic" with wrong RBW and wrong traces
  • #9761: ErrorReport: "RBW switched to Auto(100kHz) during 30M-1G test
  • #9775: Rohde & Schwarz ESPI 3 Scanning Receiver: Specific System Error: -222,"Data out of range; SCAN1:BAND:RES 9 KHZ.
  • #9783: Driver: MT 400 D
  • #9798: When RE MB test is interrupted and resumed, another RBW is being used
  • #9847: RBW changed, radimation halted
  • #9956: Radiated Immunity MB - Graph is not drawn
If you have specific questions regarding on of the above items, please contact us at support@radimation.com
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2018.1 .
