New Version: RadiMation version 2021.1.8
Jeru
Post by Jeru »
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.1.7 version.
This version 2021.1.8 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.1.8 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following issues are fixed in this 2021.1.8 version (compared to the 2021.1.7 version):
  • #11504: Driver: Solar Electronics 2352-1.
  • #11505: Driver: Teseq CBA-series amplifiers.
  • #11660: Driver: Comtest Engineering MCP-01 switch matrix
  • #11755: Driver: Bonn BLMA 2060-50 Band 1 to 5
  • #11777: Driver: PMM Antennas.
  • #11780: Driver: EMC Shop DC1G-1000A coupler.
  • #11781: Driver: EMC Shop DC6G-250.
  • #11788: Export limitline graph as table in test with Frequency unit as kHz raises Frequency too large exception
  • #11796: Duty cycle is not visible in Burst measurement.
  • #12071: ErrorReport: "fout bij RE > 1 GHz".
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.1
