New version: RadiMation version 2023.2.6
Jeru
Post by Jeru »
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.2.5 version.
This version 2023.2.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.2.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.2.6 version (compared to the 2023.2.5 version):
  • #12424: INNCO CO3000 firmware vesion 1.03.09 has problem with retrieving polarisation
  • #13474: Drivers added for the EMI mode of the Rigol RSA3000-series and RSA3000E-series
  • #13630: Added Possibility to configure the preselector of the TDEMI series
  • #13811: Improved retrying to resolve Error 130 when controlling RadiPol antenna tower
  • #13883: Fixes related to loading the advanced settings
  • #13967: Enable alignment warnings for the N9038A
  • #14112: N9010B Wrong RBW in Final Peak Measurement
  • #14146: Rigol analyzer returns unexpected results during BCI Calibration
  • #14219: Rigol RSA-series analysers: Socket based communication on port 5555 now possible
  • #14220: Possible to control Rigol RSA3030E on LAN port 5555
  • #14221: *OPC? is also included in the RadiLog when TCPIP device stream is used
  • #14241: RE TDEMI buffers a sweep taken before the pre-amp is state is changed
  • #14257: Driver: AMP 2104
  • #14264: Firmware version check for Rigol RSA3000E series is now checking on firmware version 00.01.04
  • #14295: Unit not changing to dBuA from mA in CS114
  • #14297: Gauss Instruments TDEMI controlled in spectrogram mode uses actually taken number of sweeps for second detector
  • #14299: Fieldfox N9912A Check correct option values
  • #14310: Driver Wavecontrol SMP 3
  • #14313: Limit line must be enabled for the measured detector type
  • #14316: Correct default TCP/IP port number is selected again when it is removed from the Ethernet address configuration
  • #14316: Set the default port in the TCPIP communication string if it is removed during configuration
  • #14317: More securely pass variables to multithreaded combine of correction files
  • #14322: Extend configurable amplifier drivers to perform an additional optional read
  • #14326: Changed description of the graph division settings frame
  • #14329: Changing the 'max measure' in the powermeter settings is not possible using the keyboard
  • #14341: Driver for adjustment of RadiField amplifier input attenuator
  • #14342: Driver for advanced measurement values of RadiSense Ultra
  • #14350: Keysight N9000: Fix Wrong RBW during final measurement
  • #14357: Do not start the RadiField gain adjustment while this is already started
  • #14370: Improved auto detection of actual terminator used by Raditeq devices
  • #14376: SMF100A carrier is limited to minimum level
  • #14376: SMF100A carrier is now limited to the minimal possible level
  • #14377: Driver: R&S EPL
  • #14379: Support the RS OSP B103 module
  • #14382: Revert change which sends an unsupported command to the SMB100B related to setting the minimal carrierlevel
  • #14399: Keysight N9000: Meter average detector is set in receiver mode
  • #14409:Error in Av measurement during CE
  • #14415: R&S ESRP: Correctly select the fixed attenuation value when the same as the auto attenuation value
  • #14420: Increase the power measurement observation time of RadiPower when measuring AM modulation
  • #14421: Requesting the average trace in the pre-scan results in unexpected data returned
  • #14423: Rigol RSA3030E-TG is used in GPSA mode instead of EMI mode
  • #14432: Improved initialisation time of a USB connected RadiPower RPR2006P
  • #14433: Siglent generator time out problem when sending the OPT command
  • #14448: Baudrate of RadiPower RPR2006 is not set again if it is already using that baudrate
  • #:14471: Device driver message boxes should show the brand and description
  • #14484: Power Meter Boonton 4220A not recognized
  • #14491: Firmware update of RadiPower 4000 series does not raise an 'ERROR 1' anymore
  • #14492: RadiPower driver waits until unit has finished restart after a firmware update
  • #14493: Corrected typing error 'faling' to 'falling'
  • #14509: Checking for updates raises a 'server cannot be found' error
  • #14539: R&S SMC100A is always set to 0 dBm
  • #14546: Error when controlling a R&S NRP connected to a R&S SMB100A
  • #14550: Update version number checks in driver for RadiSense Ultra
  • #14556: Caption in tab of advanced device driver configuration shows _ instead of &
  • #14559: Low and High range selection for the Radisense 3018U
  • #14560: TSF is not blank anymore after click cancel in sequence window
  • #14585: Driver: Ceyear 1465-series and 1466-series signal generators
  • #14586: Two dongles are now correctly supported
  • #14596: RepGen: Possibility to reapply the table styles to a table
  • #14603: Raditeq RadiSense RSS3018U: The range selection is by default hidden
  • #14605: OSP B103 module does not remember selected state
  • #14607: Generating a report using the RADICLI.EXE is only possible when the desktop client is running
  • #14611: ESU40 Receiver does not return data when measuring bands with a 0 Hz span
  • #14613: RadiSense 3018U: Do not request device specific inputs related to the laser temperature and current
  • #14615:Radimation Closed after choosing multiple Files in EUT-Attachments Tab
  • #14169: Error NRP could not be found while running the test
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.2.
