New version: RadiMation version 2024.2.5
Posted: 04 Jun 2025, 10:47
by Jeru
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.2.4 version.
This version 2024.2.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.2.5 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2024.2.5 version (compared to the 2024.1.x version):
  • #15034: Add option to disable automatical log-in of engineers
  • #15257: Multiple measurement of the Keysight 34400-series multimeter are performed during the dwell time
  • #15282: Improvements related to sharing of device stream run time configurations
  • #15458: Improvements related to sharing of device stream run time configurations
  • #15704: Add Ametek GTEM cell drivers
  • #15756: Fix the correction file contains the column 'Attenuation' which is not allowed'
  • #15796: Option to ignore connection errors when Netatmo is unavailable
  • 15798: Driver: Modulation source Agilent 33511B
  • #15816: Switch commands for the R&S OSP are retransmitted when an error is raised
  • #15825: Show 'RadiMation 30 years' logo's on about window
  • #15826: Fix TESEQ CBA 1G-300D reboots when initialised
  • #15832: UCS 500N Set the nominal and reduced voltage using U- commands
  • #15836: Fix FC06.1 times out after activating the tilt mode
  • #15839: Updated documentation regarding usage of magnetic field antenna factor
  • #15851: Edit sequence button is working again
  • #15854: CWS 500N1 device driver function not implemented
  • #15855: Extend Lumiloop 1.2 driver with multi axis readout functionality
  • #15859: Fix index out of bounds error when pasting correction data from excel
  • #15865: Updated wiki page for the "Timeout while waiting on a response that matches with the regular expression" error
  • #15878: KEYSIGHT MSOX3034T select the correct channel
  • #15886: Improve communication with ETS-Lindgren amplifiers
  • #15983: Limit frequency to the AC/DC coupling start frequency
  • #15902: Correct error handling for getinfo call for the the XYZ postioner
  • #15903: innco CO2000 and CO3000 auto detection
  • #15905: Powering of RS232 devices using the DTR line is now allowed by the RadiVISA layer
  • #15906: HP34465A cache the max, min and last value correctly
  • #15938: An item with the same key has already been added
  • #15950: Driver: Rohde & Schwarz ESU/ESR/ESW/EPL Controlled LISN
  • #15952: Add reseller: EM Test Solution
  • #15956: AC/DC coupling selection in ESCI scanning receiver
  • #15959: Driver: IFI SCCX750
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.2.
[/quote]
