New version: RadiMation version 2013.1.12
We continued our development of our RadiMation software, and we included several improvements and fixes for problems that have been detected since the release of the 2013.1.9 version.
The following issues are fixed in this 2013.1.12 version (compared to the 2013.1.9 version):
  • #4242: Issue measuring time setting in MB
  • #4269: Settings (RBW) differ in comparison with measurement results
  • #4541: Driver: Bonn amplifier BSA 0125-125
  • #4596: Problem with PMM in latest version
  • #4716: Reference Level is not correctly set during final measurement
  • #4718: COR file graph is not correctly drawn
  • #4750: RadiMate AD converter is not working
  • #4752: PMM 9010 timeout errors
  • #4754: EMCO 4825/2 LISN error Start frequency was too low
  • #4758: Detector Keywords for report generator template
  • #4759: PMM is not detecting that it isn't getting any real data
  • #4763: PMM 9010 Error detected during start sweep measurement
  • #4765: RI Uniform Field Area calculation form
  • #4766: Frequency Change Mode configuration button is not present
  • #4781: Driver: Agilent N5171B Signal generator
  • #4782: Driver: AR 1000W1000D amplifier
  • #4783: Driver: AR 2500A225 amplifier
  • #4785: Configuration to remote control RSW1002E on 12V
  • #4786: Not possible to printout a MB test
  • #4791: RI Fixed power test in a sequence doesn't remember that a frequency list should be used
  • #4798: R&S ESAI EMC receiver
  • #4803: Move and Turn during measurement settings are disappeared
  • #4807: RDM1004A with RadiCentre 1 is not connecting
  • #4816: Driver: Wandel & Goltermann EMR-10 + EMR-11
  • #4817: Menu Help > Suggestion URL is opening DARE homepage
  • #4819: Continuity between LLF and COR
  • #4848: Error message when printout a Multiband test
  • #4813: RM crashes during search of DARE products
  • #4837: Initializing a powermeter while on the envelope or burst mode tab, is not working correctly
  • #4844: Changing the sample rate for the RadiPower in envelope trace mode is not working, if 1E+3 notation is used
  • #4857: RadiPower RPR3006P measurement should be corrected for the Modulation bandwidth that is used by the EUT
No changes have been made to the measurement algorithms and correction calculations.
Some small improvements and new functionality is included in this 2013.1.12 release, most important are:
  • The RadiPower control window has some general improvements
  • Several user interface issues with the Customer database connection have been improved
  • The Customer Database connection to Microsoft Outlook has been updated
The new 2013.1.12 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
