New version: RadiMation version 2013.1.13
Today we released a new version of RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2013.1.12 version.
The following issues are fixed in this 2013.1.13 version (compared to the 2013.1.12 version):
  • #1085: Field measurement during CI testing
  • #2657: A graph of an AD-Input should auto scale the y-axis to also show the limits that are relevant for the AD-Input
  • #2853: Multiband Report generator code for an ad-channel should also be available as a pre-determined code
  • #2904: EUT ad channel monitoring scale is wrong, no information is displayed.
  • #3031: AD Graph 1 does not work in multi band
  • #3236: Max limit is not viewable when all the measurements are above the limit
  • #3564: R&S ESVS device driver should be updated to use double parameters
  • #3867: Net power and calculated current on the CAN-bus
  • #4167: Power meter driver for fsiq / FSEK and fsp
  • #4171: Report generator: keyword for step frequency is not working
  • #4582: Wrong peak is measured with final peak measurement selection
  • #4615: Error 'Settings conflict: step size clipped to nearest value allowed'
  • #4642: Modulation settings are not correctly saved
  • #4682: Selected peaks do not match with selected peaks in the peak table
  • #4711: Peak zoom-in is not working correctly if a limitline file is specified
  • #4728: All peaks above the limit dB value is not retained
  • #4745: RadiMation shortcut should have version number
  • #4753: HP8542E Receiver is measuring only one sweep and only one band
  • #4764: RadiCentre problems
  • #4824: Setting conflict error with a Agilent Scanning Receiver
  • #4859: RadiPower misses the last part of a pulsed signal
  • #4864: Driver: EMGen 7003-001
  • #4865: Controlling a RadiGen is raising a dialog with the message: Operation is NOT completed
  • #4868: Remaining test time is shown in 12:04:30 AM notation
  • #4870: Installation on a PC cannot be completed due to network location configuration
  • #4871: Limit values of ad-channels are not used in the scaling of the ad-channel graph
  • #4872: Installation of drivers.exe generates an error regarding registration of RADCANoeWrapper
  • #4879: How should the magnetic field antenna factor be specified?
  • #4883: Wrong readings during conducted immunity fixed current test
  • #4895: Driver: RSS1006A Device Not Connected
  • #4896: RSW1021N and RSW1024S errors 'Not all bytes are written to the GPIB board within the timeout period'
No changes have been made to the measurement algorithms and correction calculations.
Several improvements and new functionality is included in this 2013.1.13 release, most important are:
  • The AD-channel graphs now use an improved auto-scaling that also shows the related AD-channel limits
  • The AD-channel graphs of a Multiband test can now more easily be included in a report (keywor: ||AD GRAPH 1||, ||AD GRAPH 2||, etc...)
  • The powermeter device driver for the R&S FSP/FSIQ/FSEK/ESI has been improved
  • Peak detection and final measurement is improved if the detected peak is far below the limitline
  • The setup program is further improved to handle some small issues
  • The interfacing to the CANoe/CANAlyzer software is reviewed and improved
  • The control of the Agilent N9000A-series (MXA, CXA, PXA, EXA) has been improved
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2013.1.
The new 2013.1.13 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
