New version: RadiMation version 2013.1.14
Today we released a new version of RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2013.1.13 version.
The following issues are fixed in this 2013.1.14 version (compared to the 2013.1.13 version):
  • #693: There is no logical order in the selection of the controls, if the selection is moved with the 'TAB' key
  • #3235: Cancel button in report generation is not cancel but skip
  • #4047: First point from final measurement is not measured correctly
  • #4112: Final measurement at wrong frequency
  • #4202: HI field probe readout raises errors
  • #4216: Incorrect QP measurement on first peak measurement
  • #4287: Mast sometimes doesn't move with HD100 antenna controller
  • #4414: Maturo NCD no VISA available
  • #4669: Disable the spell checker during the generation of the report
  • #4710: Only the first line from NOTE is showed in test list
  • #4736: RG: Object reference not set to an instance of an object
  • #4746: First Measured Peak is not correct with R&S ESVS 10 / ESHS 10
  • #4793: Driver: Apsin 6010 Signal Generator
  • #4818: Add direct link in Menu Help for 'Latest device drivers...'
  • #4876: RunMacro(AutoFitThisTable) is auto fitting the wrong table
  • #4877: Agilent 4440A is not working correctly in an attenuation/gain calibration test
  • #4878: HP8542E is resetted twice during the initialization
  • #4880: RadiGen doesn't always activate the AM modulation
  • #4881: Driver: GPIB and VISA support for the AnaPico APSIN signal generators
  • #4882: Detector measurement time is not correctly set in the PMM9010
  • #4886: HI-4450 probe error without description
  • #4887: Accents and special characters are replaced with question marks icons
  • #4889: Endless loops Maturo NCD AT after communication is out of sync
  • #4890: Position Maturo NCD AT is not alway set exact by driver
  • #4891: Maturo NCD TT minimum step size of 3 degrees
  • #4893: VISA (GPIB) controlled RGN error Invalid buffer mask specified
  • #4894: RadiMation Free can't connect with RPR Power meter
No changes have been made to the measurement algorithms and correction calculations.
Several improvements and new functionality is included in this 2013.1.14 release, most important are:
  • Accented characters in the name of customers are correctly shown again
  • Several Report generator improvements
  • Improvements in the control of the PMM9010
  • Help menu has more links to relevant information
  • Antenna tower could be controlled to a height, which was 1 cm below the desired height
  • Several device driver improvements
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2013.1.
The new 2013.1.14 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
Reason: Updated list of fixed items
