The following issues are fixed in this 2013.1.24 version (compared to the 2013.1.23 version):
- #1905: Pasted information of standard is not always stored
- #2773: Pressing delete on engineer window does not give the additional are you sure window
- #2815: Combo box in EUT information list does not update its dropdown box size based on the content
- #3096: X-axis grid lines at graphs starting at 10 Hz are not correctly calculated or drawn
- #3232: Default log in test engineer can not be turned off.
- #3271: Questions to "Login-Procedure"
- #4237: No extension created
- #4521: Enhanced Status Window up down triggers Unhandled exception
- #4536: Unhandled exception for object name icon
- #4644: RI Singleband Fixed Field cannot use a 1 Hz step frequency from 80 kHz to 1 GHz
- #4717: Pass button is vanished when Surge test is started
- #4737: Report Generator: Could not copy template error
- #4738: Cannot close the EUT with PI test
- #4767: Note information is replaced with default note
- #4794: Crash in calibration mode when repeat previous test is used
- #4801: Cannot access a disposed object when canceling fixed power test
- #4814: Unhandled exception when empty snapshot is exported
- #4815: Printing LLF doesn't work
- #4847: Unhandled exceptions or Not Responding after GTEM test
- #4869: RadiCentre error The connection for the given session has been lost
- #4914: Engineer name change is not saved but will duplicating this Engineer
- #4919: Error loop when saving a new LLF with insufficient engineer rights
- #4923: Ok button of note screen is opening a new note screen
- #4940: Items names for standards are not visible
- #4966: Unhandled exception when starting RI fixed power test
- #5045: Cancel button of note screen is needed to be pressed twice
- #5058: Start frequency of < 0,0001 MHz is not retained from TSF and automatically changed to 0 Hz
- #5115: Unknown error when writing a test file
- #5143: Errors Gain compression and Harmonics tests
- #5148: Milmega AS0840-100/100 Amplifier can't be remote controlled
No changes have been made to the measurement algorithms and correction calculations.
A lot of crashes and unhandled exceptions are fixed in this 2013.1.24 version.
We also include several improvements and new functionalities, the most important improvements are:
- A lot of (random) crashes are fixed
- Saving files without sufficient rights is not causing an endless loop anymore
- Duplicated notes in the Pulsed Immunity test are fixed
- (Default) Login of the engineer is improved
- Filenames are checked to have the correct extension
- Editing of the Basic- and Product-standards is improved
The new 2013.1.24 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
