The following issues are fixed in this 2013.1.26 version (compared to the 2013.1.25 version):
- #1579: Files cannot be deleted if the password protection is turned on, even when correct password is specified
- #2827: AD Convertor in multiband immunity is using wrong channel of the ad convertor
- #3394: Radimation crashes during the init of during the test
- #4332: Not possible anymore to copy the peak table to the clipboard
- #4463: Crash RM which seems to happen during equipment check/initialising/deinitialising
- #4729: HP8342E measures only one sweep instead of 5 per frequency band
- #4742: R&S ESU 8 device driver files are missing
- #4810: Error no device driver selected for cable
- #5146: R&S HCC antenna tower timeout error
- #5178: Adjusting bands during Multiband configuration should be more intelligent
- #5180: Creating a TSF sub directory with insufficient file permissions raises run-time error 5
- #5181: No description or TSF file name is visible during Multiband testing
- #5186: Multiband immunity has problems with power regulation if regulation starts on -100 dBm
- #5187: Test continues without an error even if the RadiTurn cannot turn the table to the correct angle
- #5188: Configurable AD converter options has disappeared
- #5198: Adjust RGN drivers to have a fixed minimum carrier level setting of -70dBm
- #5210: Test is freezing and NCD Maturo turn table does no longer rotates
- #5226: Driver Amplifier Research 20S1G4 Amplifier
We also include several improvements and new functionalities, the most important improvements are:
- Copying the data of the detected peaks to the clipboard, by using a right mouse click.
- Device drivers that are removed but still are present in a testsite, is now more visible
- Problems with the power delivery test and the regulation at the begin of the test are resolved
The new 2013.1.26 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
