New version: RadiMation version 2013.1.26
Posted: 06 Dec 2013, 16:18
Today we released a new version of RadiMation software, which includes some small fixes for problems that have been detected since the release of the 2013.1.25 version.
The following issues are fixed in this 2013.1.26 version (compared to the 2013.1.25 version):
We also include several improvements and new functionalities, the most important improvements are:
The new 2013.1.26 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
- #1579: Files cannot be deleted if the password protection is turned on, even when correct password is specified
- #2827: AD Convertor in multiband immunity is using wrong channel of the ad convertor
- #3394: Radimation crashes during the init of during the test
- #4332: Not possible anymore to copy the peak table to the clipboard
- #4463: Crash RM which seems to happen during equipment check/initialising/deinitialising
- #4729: HP8342E measures only one sweep instead of 5 per frequency band
- #4742: R&S ESU 8 device driver files are missing
- #4810: Error no device driver selected for cable
- #5146: R&S HCC antenna tower timeout error
- #5178: Adjusting bands during Multiband configuration should be more intelligent
- #5180: Creating a TSF sub directory with insufficient file permissions raises run-time error 5
- #5181: No description or TSF file name is visible during Multiband testing
- #5186: Multiband immunity has problems with power regulation if regulation starts on -100 dBm
- #5187: Test continues without an error even if the RadiTurn cannot turn the table to the correct angle
- #5188: Configurable AD converter options has disappeared
- #5198: Adjust RGN drivers to have a fixed minimum carrier level setting of -70dBm
- #5210: Test is freezing and NCD Maturo turn table does no longer rotates
- #5226: Driver Amplifier Research 20S1G4 Amplifier
- Copying the data of the detected peaks to the clipboard, by using a right mouse click.
- Device drivers that are removed but still are present in a testsite, is now more visible
- Problems with the power delivery test and the regulation at the begin of the test are resolved
