New version: RadiMation version 2014.1.5
Today we released a new version of RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2014.1.2 version.
The following issues are fixed in this 2014.1.5 version (compared to the 2014.1.2 version):
  • #2513: Zoom-in factor for frequency detection of peaks > 100
  • #4226: Wrong command PMM9030/ PMM9060 to set RBW
  • #4255: Driver: strange VBW value is set
  • #4703: Still test running or still documents loaded errors without any window opened
  • #4776: Closing the 16 point result window using the top-right red cross, is not closing the document
  • #5022: Innco CO3000 is started at 100cm instead of 90cm
  • #5029: Innco CO3000 tolerance on the movement is not managed
  • #5176: Unhandled exception during Uniform Field Area Calculation
  • #5206: EUT Compression Calibration Unhandled Exception error
  • #5229: Opening Mil Std Magnetic test data is generating an Unhandled exception
  • #5231: Multiband Fixed power Unhandled exception Arithmetic operation resulted in an overflow error
  • #5232: R&S HCC Not all bytes are written to the GPIB-Board within the timeout period (GPIB:EABO)
  • #5270: Peak conservation setting is ignored
  • #5290: Update the splash screen logo of EMV to ETS
  • #5296: Unhandled Exception 'Object reference not set' for Emission X + k * S
  • #5300: Unhandled Exception 'Object reference not set' for Climat Chamber
  • #5328: Agilent Technologies N191A powermeter error
  • #4638: Closing test configuration window will open test window
  • #5042: Test is starting after closing it
  • #5238: Test is opening unwanted windows after closing it
  • #5265: Metrohm Turntable device driver
  • #5313: Readout of SOPM01/03 is slower
  • #4802: Magnetic Field method can't use TT and AT
  • #4899: Peaks detection is not correct after initial sweeps and final peaks are not/wrong measured
  • #5150: R&S SMA100A/SMC100A timeout while waiting for OPC command
  • #5236: Cannot access a disposed object after closing RadiMation
  • #5257: RM is not returning RTT1001B turntable controller motor error
  • #5297: Unhandled Exception 'disposed object' for LISN and Merge
  • #5299: R&S SMP02 Signal generator -222 Data out of range error
  • #5303: RF Amplifier Impossible to get description string (..) Unknown RadiMation error
  • #5308: R&S ESU8 timeout expired before OPC
  • #5314: RadiMation database table and fields are somethimes not retained
  • #5318: CAL file used by TSF is not easily visible
  • #5331: ESVS10 performs two scans instead of one
  • #5348: When auto trigger mode is selected for a VI Powermeter, it always remains in auto trigger mode
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.1.
The new 2014.1.5 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
