New version: RadiMation version 2014.1.6
Today we released a new version of RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2014.1.5 version.
The following issues are fixed in this 2014.1.6 version (compared to the 2014.1.5 version):
  • #284: Make it possible that files can be dragged and dropped from the windows explorer to RadiMation
  • #2354: ISO standards do not require that all raw data is stored
  • #2700: Limit line is loosing the configured color
  • #2751: Limit line files turn black after setting the colors
  • #4458: peak detection is not working properly
  • #4520: Dragging a valid RadiMation file should open it
  • #4708: EUT is only opening RadiMation and not the file
  • #4709: EUT file should open latest RadiMation version installed
  • #4735: 4446A preselector is searched when deselected in driver settings
  • #5093: Creating a new Limit Line is not shown in graph
  • #5097: Changing LLF style is not updated in graph
  • #5158: LLF color is not retained
  • #5173: Generate a maximum trace, when more than one trace is taken. We need only the maximum value
  • #5263: Driver Bonn BLMA 0832-270D
  • #5267: EMCO 1090 is not working
  • #5279: Driver AD Agilent 34972A (DAQ)
  • #5298: Add LAN communication for Agilent N5171B Signal generator
  • #5301: RF Amplifier device not connected
  • #5302: RF Amplifier Not all bytes are written (..) within the timeout
  • #5332: Automatic peak detection performed in manual mode is not working
  • #5336: Driver Agilent 34902A switch matrix 16x relay
  • #5351: NRVS communication issues
  • #5352: Configurable Signal Generator doesn't retain frequency range
  • #5363: Download of Drivers.exe is marked of being unverified
  • #5364: Setting the RBW of the R&S ESMI is not always working correctly
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.1.
We also include several improvements and new functionalities, the most important improvements are:
  • Multiband emission: Individual sweeps are combined and stored to a max-hold result, which reduces the required amount of memory and disk space
  • Improvements in the peak detection of multiband emission tests.
  • Color and linestyle of the limitlines will be maintained.
  • More device drivers are adjusted to be able to be controlled by LAN
  • Drag and dropping of a file onto RadiMation will open the file
  • Double clicking a RadiMation file in Windows Explorer will open it in the running instance of RadiMation
The new 2014.1.6 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
