New version: RadiMation version 2014.1.13
Posted: 25 Apr 2014, 13:58
Today we released a new version of RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2014.1.10 version.
The following issues are fixed in this 2014.1.13 version (compared to the 2014.1.10 version):
  • #3893: Zooming In places all peaks to one frequency
  • #5116: Peak shifts all over the frequency band
  • #5398: Detection of the RadiTurn is not working
  • #2467: ModeOfOperation is put on the window without the space
  • #3817: ESIB 40 Tracking Generator
  • #4938: Adding a new basic or product standard is not refreshing the list correctly
  • #5401: Peak detection doesn't detect peak if peak is very close to 0 dBuV
  • #1496: At the end of the test, antenna tower should go to lowest specified height
  • #2897: The unit description in the correction file is not displayed correctly, it states unknow instead of the unit
  • #3774: stepsize for receiver is not configurable
  • #4061: Unable to perform Qpk scan with R&S FSP
  • #4166: Sorting of the directory structure in the tsf selection window
  • #4182: Sweep time is doubled
  • #4388: Preamplifier R&S ESU40 Analyzer is automatically turned off
  • #4560: FSP30 rounding
  • #4564: Possibility to do Prescan and Final Measurements with different devices
  • #4588: Step frequency is not defined error
  • #4590: Selected frequency step is not supported error (R&S ESVS10 receiver)
  • #4953: Changing configuration of an Unit is not refreshing the list correctly
  • #4964: Arrows are not correctly centred in the buttons
  • #5068: Folders opened with keyboard are not showing TSF files in Select TSF window
  • #5098: After entering LLF data the wrong datafield is selected
  • #5400: RadiTurn no match was found during the specified regular expression
  • #5411: Measuring the peak will result in an endless loop of zooming-in
If you have specific questions regarding on of the above items, please contact us at support@radimation.com
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.1.
The most important improvements are:
  • Several improvements to the peak detection and final peak measurements.
  • Performing a prescan with an analyzer and performing the final measurement with a receiver is easier.
The new 2014.1.13 release of RadiMation can be downloaded from: http://shop.dare.nl/index.php?option=co ... &Itemid=54. (see: viewtopic.php?f=3&t=53 )
