We strongly advise to test this each new version of RadiMation on for example a seperate PC or laptop before you start using it on a daily basis.
The following issues are fixed in this 2014.2.7 version (compared to the 2014.2.6 version):
- #4959: Remote controlling Maturo NCD over LAN
- #5557: Reading out dBr values with Audio Analyzer UP 300
- #5650: Driver Rigol DSA815 and Rigol DSA1030 series
- #5656: Configurable Amplifier and Coupler doesn't retain frequency range
- #5664: N9038A error -410 Query interrupted
- #5688: Check on software software protection key fails
- #5702: HP8591E EABO errors can abort a running test
- #5703: How to customize and adjust the markers in RadiMation?
- #5706: R&S FSH (for field probe) is not using transducer list
- #5710: R&S ESU8 EMI error -200 Function GAIN:STAT OFF not available
- #5711: R&S FSV 13 error -113 Undefined header INP:ATT:PROT ON
- #5719: Amplifier AR 75A400 device not connected error
- #5721: Driver: PMM 7010
- #5731: Driver Agilent U2001A Power meter
- #5732: Possible stopping an immunity measurement automatically?
- #5736: No trace data obtained from measurements with FSV13
- #5746: Driver RadiField Amplifier
- #5747: Driver RadiField Forward and Reflected power meter
- #5748: Driver RadiField Coupler
- #5749: Driver RadiField Antenna
- #5764: Driver RadiPol
- #5766: RadiMate 3 RAW communication issues
- #5772: Device Driver Function Function Not Implemented error for Rigol spectrum analyzer as powermeter
- #5773: Amplifier that is already in OPERATE can result in an endless test initialization
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.2.
The most important improvements in this 2014.2.7 release are:
- More additional and improvement of device drivers
- Fixes a problem with the state changes of the amplifiers
We also strongly recommend to also download and install the latest device drivers
after the 2014.2.7 version is installed.This RadiMation 2014.2.7 release has been in use in our company for several weeks without any problems. We however advise that you verify (according to your quality system) this new RadiMation software version in your setup and with your measurement equipment, before you are going to use it for daily operation.
