New version: RadiMation version 2014.2.12
Today we released an updated major version of RadiMation software, which includes several improvements and small fixes for problems that have been detected since the release of the 2014.2.10 version.
We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a seperate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The following issues are fixed in this 2014.2.12 version (compared to the 2014.2.10 version):
  • #4238: Error field probe by polariser
  • #4900: Amplifier Information Could not be found error
  • #5237: Correction is applied when no correction file is attached
  • #5844: Advantest analyzer as powermeter is not automatically switching the attenuator
  • #5845: Using Rigol as powermeter can cause large measurement errors
  • #5866: High Peak and overshoot measurements with PMM9010F and PMM 9030
  • #5884: R&S ESU 26 Input 2 is using input 1
  • #5909: Configuration of Narrow band / broad band detection according to standards has disappeared
  • #5911: Device Not connected errors for AR amplifier 75A400
  • #4041: Antenna mast Frankonia FC 02 not working
  • #5597: Driver PMM Switching control Box
  • #5733: When should I use the Forward Power Mode and when the Net Power Mode?
  • #5893: How to perform a continuous measurement mode with continuously sweeping during turning?
  • #5908: Continuous measurement mode is not working for the Sunol SC104V Turntable
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2014.2.
The new 2014.2.12 release of RadiMation can be downloaded from the DARE!! web-site:Image
We also strongly recommend to also download and install the latest device drivers Image after the 2014.2.12 version is installed.
