New version: RadiMation version 2015.1.7
Posted: 19 May 2015, 11:47
Today we released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2015.1.6 version.
The following issues are fixed in this 2015.1.7 version (compared to the 2015.1.6 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2015.1.
The new 2015.1.7 release of RadiMation can be downloaded from the DARE!! web-site:
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
- #5856: Auto move of antenna tower is harmfull for hardware
- #5904: Keyword TEST TIME is exporting wrong data and shows TEST START TIME
- #5906: Spurious emissions with high values are detected during noise floor measurement
- #5910: Sunol SC110V customer specific Antenna Tower driver
- #5917: Final peak measurement with ESR 7 blocks the software
- #5925: Configurable Signal Generator is missing the Remote Control checkbox
- #5939: Strange measurements with the R&S ESVS20 Test Receiver
- #5940: HP 33120 signal generator raises error 1 -113
- #5946: Driver AR 40S4G18M4 Amplifier
- #5961: A 1 hour multiband immunity test causes an algorithmic calculation error
- #5964: R&S ESR7 Specific System Error -141 Invalid character data SWE:SPAC APUL
- #5980: The entry "Configurable EUT Controller" is in the driver list of Switch Matrix and not in the list of "EUT Controllers"
- #5986: Frequency up/down is not working in multiband immunity manual mode
- #5987: Driver Milmega AS0827-55 amplifier for IEC61000-4-3
