The following issues are fixed in this 2015.1.8 version (compared to the 2015.1.7 version):
#5052: Reference level is changed during measurement, generating an IF overload
#5829: Frequencies labels are not correctly updated in a Mutiband TSF
#5950: Driver Amplifier Bonn BSA 0106
#5976: Saving a Pause Test is generating several 'file corrupt' problems
#5983: Driver for obsolete field probe PMM8052
#5998: What means: 'before', 'during' and 'after' on the EUT Monitoring channel
#6002: Do not change the reference level. Leave it fixed on the selected level
#6030: AR FP 3000A Field sensor is not connected
#6034: New EUT Monitoring channel configuration is not working in Singleband immunity
#6035: Values specified in the Min and Max of AD Input Range are lost
#6037: Driver National Instruments Switch (NI USB 6218 BNC)
#6038: Driver HP 83650A Signal generator
#6039: Driver FSP 40 as powermeter
#6040: Driver CBL 6112C
#6043: Units configuration is not applied to test
#6045: Auto save function after completion of (Multiband) tests is polluting the EUT
#6051: Possibility to send switch command before power on for the Configurable Amplifier device driver
#6052: Configurable amplifier device driver is sending the standby command at start of test and operate command after the test
#6056: Monitoring input channels from channel 33 and higher are not working
#6079: Problems with Software Protection Key dongle
#6089: No graph or table information is exported in manual mode test data
#6092: Different antenna polarization errors during UFA calculation
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2015.1.
The new 2015.1.8 release of RadiMation can be downloaded from the DARE!! web-site:
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
