New version: RadiMation version 2015.1.10
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2015.1.8 version.
The following issues are fixed in this 2015.1.10 version (compared to the 2015.1.8 version):
#3503: The configurable signal generator does not allow the setting of the external modulation settings
#4410: Changed modulation settings are not applied
#4831: Not possible to see actual values in table mode
#5467: Hide all table information is not working
#5782: ESRP raises an error for an unknown header: INP:GAIN:LNA:STAT OFF
#5796: Setting the frequency is showing rounding issues
#5915: Driver: Keithley Arbitary Generator 3390 as modulation source
#5947: Modulation of Marconi 2024 Signal generator is never turned off during CI test
#5960: Pulse modulation settings in the singleband fixed power manual mode window are not forwarded to the signal generator device driver
#6054: Cross thread operation detected error
#6057: Keyword ||RADIMATION VERSION|| is exporting 201x,x instead of 201x.x.x
#6061: Can not save LLF anymore after making changes
#6065: Multiband PM Modulation Configuration setting is not retained
#6066: Windows Universal Naming Convention (UNC) is causing error "Access to the path.. is denied." when creating a new TSF directory
#6078: Opening a test in a newer version overwrite test data used RadiMation version
#6085: Support 2 Hz AM modulation in RadiGen
#6095: Driver Bonn BTA 0122-3000
#6099: RadiCentre is still in remote after deinitialisation
#6102: Overshoot detection of the EMCO1060 is not working
#6103: Suggested product id number for instrument descriptor of NRP power meters is wrong
#6107: R&S BBA100 RF path is not being switched between bands
#6111: R&S AFG device check seems to be always successful
#6112: R&S BBA100 RF option to always keep amplifier on
#6113: External Modulation Source settings are lost
#6114: Configurable Signal Generator Modulation settings are not retained
#6115: Enable wxWS_EX_VALIDATE_RECURSIVELY for all device drivers
#6116: Move during measurement should not be visible in an immunity multiband test
#6120: Configurable Modulation Source carrier level is not send
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2015.1.
The new 2015.1.10 release of RadiMation can be downloaded from the DARE!! web-site: Image
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
