New version: RadiMation version 2015.1.11
Posted: 31 Jul 2015, 11:32
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2015.1.10 version.
The following issues are fixed in this 2015.1.11 version (compared to the 2015.1.10 version):
#5683: Driver EPI1001A CTR plugin card
#5947: Modulation of Marconi 2024 Signal generator is never turned off during CI test
#5971: Driver: Fluke45 as multimeter
#6151: Advantest R4131D No match was found in the specified regular expression errors
#6161: Graph Customization Configuration button Restore factory default is always disabled
#6166: Verification TESEQ drivers
#6169: RPR device driver is crashing RadiMation
#6173: First sweeps Advantest TR4172 are jittering, causing wrong measurement results
If you have specific questions regarding on of the above items, please contact us at support@radimation.com
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2015.1.
The new 2015.1.11 release of RadiMation can be downloaded from the DARE!! web-site:
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
