New version: RadiMation version 2015.1.12
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2015.1.11 version.
The following issues are fixed in this 2015.1.12 version (compared to the 2015.1.11 version):
  • #3821: Test equipment not correctly changed in radiated immunity multiband
  • #5250: Change format of graph export per default
  • #5402: Driver: AR 20ST1G18 Amplifier
  • #5595: Driver R&S Vector Signal Generator SMBV100A
  • #5596: Driver: AR 50ST1G18 amplifier
  • #5670: How to integrate probe calibration values into RadiMation
  • #5871: Metrohm Antenna Tower device driver
  • #5892: Turning on modulation of R&S SME is having a hardware delay
  • #6033: Extend driver for Agilent 34401A Multimeter (AD Converter) with VISA communication
  • #6063: HP 4417A Power meter issue
  • #6136: Driver Frankonia controller Model FC-06
  • #6200: The AD Channel configuration window is not responsive when it is shown the first time
  • #6202: Show the DeviceStream configuration of a device driver in a panel below a combobox
  • #6208: Driver: IFR2398 Spectrum Analyser
  • #6209: Configuration National Instruments AD converter for channel 9 and higher
  • #6211: HI 6105 Device Driver Function Not Implemented
  • #6212: HI 6105 wxDynamicLibrary already loaded error
  • #6213: HI 6105 always tries to switch to local
  • #6214: Driver Prana DP600 amplifier
  • #6221: Driver Anritsu Spectrum Master MS2713E as field sensor for 2000-1791-R antenna
  • #6222: How can we change the speed of the Maturo turntable
  • #6224: Extend driver for Agilent 34401A AD Converter with VISA communication
  • #6225: Driver Manual Controlled AD Converter
  • #6226: No values for National Instruments AD converter channel 9 and higher
  • #6232: How to measure the Frequency and duty cycle with Oscilloscope or AD Converter
  • #6234: Directly raise an error when device is disconnected
  • #6249: Wrong AD Channel is selected for RadiSense probe
  • #6272: Driver of Keysight Technologies N9038A is checking for the 'Agilent Technologies' *IDN? response
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2015.1.
The new 2015.1.12 release of RadiMation can be downloaded from the DARE!! web-site: Image
We always advise to thoroughly test EACH new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is even a requirement for all ISO 17025 accredited test-labs. To enable customers to validate new software versions before they implement that new software version, we even made it possible to install multiple versions of RadiMation side-by-side on a single PC. This side-by-side installation is normally not possible with other programs but is especially implemented in RadiMation.
