The following issues are fixed in this 2016.1.4 version (compared to the 2016.1.3 version):
- #423: Configuration of customer database is not retained
- #4809: Driver: Hameg HMS3010 Spectrum Analyser
- #5211: Driver: Maturo NCD controller advanced error checking
- #5228: HP8594E GPIB error
- #5314: RadiMation database table and fields are sometimes not retained
- #5492: System error checking on HP 8562/8563 causes communication errors
- #5969: R&S ESU EMI receiver is only set to integer frequency values
- #6175: Driver: Thermo Scientific EMCPro-PLUS
- #6429: Peak Maximise settings change doesn't work
- #6810: Driver: Lutron EMF-819 Fieldsensor
- #6839: Forward power column in the table of Amplifier linearity is not showing the first powerlevel
- #6871: Driver: Hameg HM8135
- #6902: Keywords TEST SITE EMAIL ADDRESS and CLIENT EMAIL ADDRESS are not working anymore
- #6957: Not possible to export a fixed field to a CAL file, errors is shown that modulation was used is shown while this is not the case
- #7004: Pasting large data (19000 rows) into a COR file is crashing RadiMation
- #7032: GPIB communication is slower with newer drivers
- #7033: Unknown error message RadiField. Error 530
- #7040: Marconi signal generator doesn't respond on *STB?
- #7045: Cannot find Modulation source in the currently active testsite
- #7052: Crash: CE MB Antenna Terminal measurements
- #7056: 1st correction file selection of antenna shows: 'Select a correction file'
- #7057: HP 8594E analyser as a power meter returns Not all bytes are written to the GPIB-Board
- #7061: Graphs and table of Amplifier linearity test is unlogical
- #7075: sorting of columns of the peak table is not working correctly
- #7076: Exporting field strength to calibration is not working, because a modulation is selected, even if 'No Modulation' is selected
- #7084: HP85xx-series: Incorrect measurement: Emission values up to 330 dBuV/m
- #7086: Setup downloads .NET 4.6 instead of .NET 4.6.1
- #7094: Bonn amplifier should be placed in REMOTE, also on GPIB
- #7105: Unlogical Red cross in AD Configuration dialog
- #7108: Selection of CapacitiveClamp on EMTest UCS500N not correct
- #7113: Polar graph is not drawn correctly, when the window has been maximized
- #7117: Driver TTi TGR2050 Synthesised RF Generator
- #7119: RadiMation does not start up after modifying global/standalone directory
- #7124: Object reference not set to an instance of an object: Frequency drawing of bands control
- #7127: Font of the legend on the polar plot is much smaller than on the frequency graph
- #7128: Index was outside the bounds of the array error 536879965
- #7136: Unable to report error manually
- #7138: Issue with our home made 40 channel AD Converter
- #7141: AD Converter error during test initialization
- #7145: Output of multiple channels using LeCroy WaveSurfer Channel switch matrix driver during single band test
The new 2016.1.4 release of RadiMation can be downloaded from the DARE!! web-site:
