The following issues are fixed in this 2016.1.6 version (compared to the 2016.1.5 version):
- #5864: Preamplifier and reference setting have no effect for the ESL6
- #6259: ALL RADIATED EMISSION TESTS is not replacing keywords of corresponding tests
- #6687: Driver: Luthi MDS22
- #6766: Measuring settings Lines/Neutral with LISN
- #6883: Using radiated immunity for shielding effectiveness
- #6915: Driver: Schwarzbeck BBA 9106 antenna
- #6916: Driver: Schwarzbeck MDS21 Absorbing clamp
- #6922: Driver: Teseq CBA 230M-80 amplifier
- #6923: Driver: Teseq PMU6003 Powermeter
- #6924: Driver: TESEQ DCP 0100A Directional Coupler
- #6925: Driver: Teseq KEMZ 801 Injection Clamp
- #6926: Driver: Prana MT440DC Amplifier
- #6927: Driver: Teseq NSG437 ESD generator
- #7048: Selection of 'Neutral' LISN line is wrong when restarting last TSF
- #7129: Corrupt Customized.xml will raise an error and crash RadiMation
- #7229: HP 8594E Spectrum analyser is not following signal generator.
- #7237: Report Generator graph only shows peak markers without the trace itself.
- #7243: Probe numbers are not shown anymore in the Field inputs dialog
- #7273: Behaviour of the ||EUT|DESCRIPTION|| Report Generator keyword
- #7280: Tabs of Device specific settings on the devices Virtual Instrument window are not shown
The new 2016.1.6 release of RadiMation can be downloaded from the DARE!! web-site:
