The following issues are fixed in this 2016.1.9 version (compared to the 2016.1.8 version):
- #1957: Wrong message when no impedance file is selected
- #3001: Manual is missing information on how the corrections (and the to be used columns) should be used
- #3444: LISN ESU User port lan device
- #4975: Sorting of table frequency data in the Report is incorrect
- #5815: Driver Agilent N1911A powermeter
- #5863: Error File is not found: %s when opening TSF or after crash
- #5994: Test initialization failed for Agilent N5181A-506 with Pulse Modulation option
- #6177: CARAD EUT Controller driver raises Ethernet not connected errors
- #6752: The Device Specific value 'Power' of the powermeter should be renamed to 'Uncorrected Power'
- #6902: Keywords TEST SITE EMAIL ADDRESS and CLIENT EMAIL ADDRESS are not working anymore
- #6933: Driver Luthi MDS 20 Absorbing Clamp
- #6934: Driver EMCO 3158 Antenna
- #6935: Driver CBL 6144 antenna
- #6936: Driver ARA DRG 118a Antenna
- #6944: Driver Holaday HI4422 FieldProbe
- #6951: Driver Schaffner NSG 2070
- #6961: Description for this error is not available is shown during startup
- #6964: Ability to have Start and Stop Dwelltime events for the NI 6218 switch matrix
- #6993: RadiGen RGN6000B Setting the output level raised an error
- #7010: Use a NI USB6501 to switch between forward and reflected power
- #7024: Problem solving for the test setup of a Conducted Immunity Mil Std Calibration
- #7025: Driver Rohde & Schwarz ESW26
- #7040: Marconi signal generator doesn't respond on *STB?
- #7197: Driver Generic National Instruments Output Switch
- #7275: Switching matrix OSP 120. Relay K11 on slot 3 doesn't switch
- #7291: RadiGen RGN6000B HF Returns error: -222 Data out of range
- #7298: TCPIP Communication is not working correctly for the TDEMI
- #7304: TCPIP controlled TDEMI Powermeter raises a crossthread error message
- #7311: Driver Aaronia Spectran HF-60100 V4 X
- #7314: Insert additional frequencies
- #7340: Driver AE Techron 7224
- #7341: Driver OSR C21A8
- #7342: Driver TESEQ CIP 8136
- #7343: Driver Rohde & Schwarz ESW8
- #7345: Driver Agilent 87405A pre-amplifier
- #7346: Driver Agilent 34401A
- #7348: Driver Agilent 54831B as oscilloscope
- #7349: Driver Agilent 34401A
- #7352: Driver Antenna Schwarzbeck BBHA 9120J
- #7353: Driver Antenna Schwarzbeck STLP 9128ES
- #7354: Driver Directional Coupler werlatone C7354
- #7356: Driver AR 500W1000B
- #7381: R&S ESL6: Several GPIB communication problems
- #7397: RadiField RFS1006B Returns Error 521. Driver 3 current out of range
- #7403: Communication with plugin cards is lost
- #7424: Keysight N9083A runs incredibly slow after 3.6 GHz in scanned receiver mode
- #7433: Not all data is recorded in RE GTEM
- #7461: Unable to use formula option in AD converter
- #7466: RadiField RFS1006B Returns Error 560. Communication amplifiers failed
- #7478: EFT/Surge and VDI Report Generator keywords overview
- #7480: Question regarding R&S IMS device drivers
- #7483: Update the RadiMation software requirements
- #7486: RSW1024S Interlock: Not all bytes are written to the GPIB-Boadr within the timeout period
- #7487: RadiField RFS1006B Returns Error 526. time out error GPIB
- #7488: RadiField RFS1006B Returns Error 1087. Signal power went to high (-6dB) during power delivery test
- #7493: RadiField RFS1006B Disconnecting error: No amplifier connected
- #7494: Kalmus amplifiers cannot be controlled. GPIB: No listener on the bus
- #7495: RadiField RFS1006B Power off after disconnecting device
- #7502: Extend the IDocument interface to also return an unique IDataIdentifier
- #7503: Change the implementation of IGraphElement::DataIdentifier to also use the IDataIdentifier of the data document as the parent IDataIdentifier
- #7504: List of available graphs should use the IDataIdentifier of the graph element
- #7508: End frequency is not correctly stored in an attenuation/gain system calibration
- #7516: NI DAQ Error 6009 Unable to keep up with the hardware acquisition
- #7521: How can the complete graph data of the polar plot be exported as table data?
- #7534: SMR40 driver slowed down in communication
- #7538: How to disable the power delivery test?
- #7539: Driver Antenna BBA 9106
- #7541: Driver PowerSensor Agilent N1911A
- #7543: Driver Antenna SBA 9113
- #7547: The used and installed version of the NI GPIB Library should be logged in RadiLog
- #7548: Setting the VISA communication setting to the Visa-ID is automatically being changed to RS-232
- #7550: Driver Broadband Preamplifier Schwarzbeck BBV 9743
- #7556: Extend the license that the user agrees that RadiLog and other reported gathered data being send might contain confidential content
- #7558: Driver Keysight EXG N5173B signal generator
- #7562: Driver SG6000 Signal Generator
- #7564: Driver Measuring amplifier B&K 2636 Analog, 1 channel (via GPIB now)
- #7570: Driver Directional Coupler Warlatone C9475
- #7571: Driver Teseq CDN M016S
- #7572: Driver Teseq CDN S501AS
- #7573: Driver CDN S751AS
- #7574: Driver Werlatone C5982 Dual Directional Coupler
- #7577: Easy merge of multiple EUT Attenuation/Gain corrections to one correction
- #7583: ETS-Lindgren HI-6053 error No match was found in the specified regular expression
- #7584: Driver Generic NI DAQ mx AD Converter device driver
The new 2016.1.9 release of RadiMation can be downloaded from the DARE!! web-site:
