The following issues are fixed in this 2016.1.10 version (compared to the 2016.1.9 version):
- #2533: Power conservation is not clearly described in the user-manual
- #3917: Nonexistent peak and wrong final measurement with PMM during conducted emission multiband tests
- #4550: Driver: EM-Test Signal generator CWS 500
- #4596: Problem with PMM in latest version
- #5989: Driver: emtest CWS500N for IEC61000-4-6
- #6328: Driver FSV-3 as powermeter
- #6383: Error -222 Data out of range;INP:ATT 50 DB while deinitializing a R&S ESL 6
- #6767: Too much reflected power in combination with the RadiField
- #6955: Error too much reflected power due to RadiField reflected power value
- #7030: Driver: CWS500N2 EMTEST
- #7080: Driver: EM test CWS 500N2.2
- #7232: R&S ESI26: Data out of range: 1 Hz RBW during powermeasurement
- #7323: Prana MT400 Not all bytes are written to the GPIB-Board within the timeout period
- #7324: Prana MT400 Amplifier still in operate
- #7325: Prana MT400 Amplifier not always to RF-ON
- #7446: Reflected powermeter measurements data is incorrectly shown
- #7463: Test duration takes a lot of time as compared with a old software used before
- #7505: Frankonia FC 06 Turntable Error -33072 (Invalid target position)
- #7508: End frequency is not correctly stored in an attenuation/gain system calibration
- #7524: Driver NOVOTRONIK GTS5611 switch matrix
- #7525: Driver NOVOTRONIK GTS5601 switch matrix
- #7530: Selecting 'AD converter selected in testsite' as monitoring input device is default selecting 'nothing' instead of channel 1 resulting that nothing will be measured
- #7553: How to configure default graph log or linear scaling?
- #7554: Driver Advanced settings for ESU 40 as a powermeter
- #7592: RadiMation does not trigger a GetCurrentStatus after Operate and PowerOff
- #7599: Driver: AR FL7218 Field Probe
- #7601: RadiPower RPR2006 powermeter Windows device drivers
- #7602: Bonn Testsystem
- #7605: GPIB-Board is not controller in charge (CIC) GPIB: ECIC
- #7607: Shifted Report Generator table
- #7615: Does the driver of the Power meter E4417E performs reading of the peak value?
- #7620: PI EFT singleband Report generator codes empty
The new 2016.1.10 release of RadiMation can be downloaded from the DARE!! web-site:
